rs turbo mk4 van £290, s2 gearbox£120, seats, ect
£60, rear spoiler for an escort mk5 van,
£120, s2 gearbox with approx 40k on it
£50 mk4 van single piece rear door
£120, turbo technics aprox 15k no play in shaft, now sold
£50 this s/s zaust was on my mk5 van
£100 the pair, perfect working order, plastic cove broke on the one
£80 s2 recaros but has the mounting frame off a mk5 van, just bolted on
£300ish, van is an unfinished project, has an s2 eangine and s2 box fitted, s/s zaust, is solid on the underside, i have painted above where the petrol tank will go, has a rotten patch inside on the rear arch about 7inc just needs treating and a plate weled on it,
the turbo has some play in it,
ive had the engine running but is lumpy because i dont think the ecu has power to it or somthing,i had to link a cossy fuel pump to the pipes and a petrol can to get it running because the petrol tank isnt fitted, lowered suspension on front, s2 front bumper and bonnet.
all items are collection only from wolverhampton or i can deliver in person if your not far,
thank you for looking
nothing electrical works, wipers, lights, it does start on the turn of the key,
before i sell the van ill try to mount the tank and fuel pump so it can be seen running,but ill have to put a power switch to the fuel pump,the fuel relay will have to be found and wired to the fuel pump,
so after the electrics are sorted,tank & pump fitted, bumper fitted, seats fitted, and rusty bit welded itll be ready for its mot
for £350 you get the fuel pump, 2 recaro seats, single piece rear door,
the recaro seats will need mk4 sub frames bolted on
the van also has the lsd s2 box fitted
im in wolverhampton if you want to come and have a look
ill post pics of the bad bits this weekend
yes the engine, gear box, ecu, turbo, ss zaust, and have some newer headlights and clear indicators for it,, the pics of the separate box and things are extra parts i have laying around
as for the rear door, it will be fitted to the van soon,
i might keep the van for a little longer, that will give me time to get it on the road, then will be easier to sell
hello, not found out yet, i need to take the zaust off the van and compare it with the zaust off my mk5 van, ill pm you soon as i know
my van is mk4 m8! cheers
dont supose u have any front shocks and lowered springs for mk4, cant remember if ive asked u ive asked that many!!
May 31, 2016 09:28 PM
Matt Baxter
Sep 16, 2015 08:30 PM
