Fuel metering unit help mk4 rst
has anyone got any idea how to set 1 up?
car starts runs like shit at around 1500rpm
then seems ok, then dies then wont start again, presuming its flooded because i can smell fuel?? then seems like its running rich then starts building rpm up by itself to around 2000 then drops to 1500 ish an dies again ha ha
shall i burn it now or later?
cheers.
kev.
cheers.
kev.
Check ignition timing
11deg BTDC with vacuum to ECU unplugged
then check the idle mixture (need a CO2 meter, or know what to listen for) and see how it goes then, could be the fuel pressure needs turned down when the cars going, i.e. not at idle.
JK12
33
Apr 26, 2021 12:09 PM
chris m1
Sep 7, 2015 08:02 PM
