knock sensor
Old Jul 29, 2008 | 07:16 PM
steven botes's Avatar
steven botes
Default knock sensor
ive built an electronic circuit that interprests signals from a single wire knock sensor which actually works when you tap the sensor with a hard object. it has a LED and a buzzer which screaches when tapped - havent fitted it yet cos the back of the cvh has no spare tappings and it will be near impossible to drill and tap a hole with the motor in.
it has a 10k variable potentionmeter in it to tune it per motor/knock sensor assembly as different size engines have different knock frequencies and each type of single wire knock sensor is suited to an engine size
thinking of fitting an entension block 1/4" bsp female either side of it to fit between the oil sender and the block and half drilling and tapping the side of this block to fit the knock sensor from a toyota 4AGE supercharged motor - anyone ever fitted a knock sensor to a cvh like this?
Old Jul 29, 2008 | 07:42 PM
JesseT's Avatar
JesseT
The efi cvh block has a 8mm tapping at teh back of the block for the knock sensor. That's where I had mine installed when I still had the cvh.
Old Jul 29, 2008 | 07:47 PM
steven botes
havent seen these holes , and i have a total of 6 1.6 cvh blocks in my garage , from standard xr3 to rst to fiesta , any pics?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
