Any downsides to running a Turbo inlet restrictor?
Old Jul 26, 2008 | 10:25 PM
Mr C's Avatar
Mr C
Default Any downsides to running a Turbo inlet restrictor?
Im running a T34 with a 34mm restrictor on my track cossie, what effect will leaving the restrictor on have on the power, torque, drive and feel etc of the engine, will it reduce power or strangle the engine etc. Im planning on having an adaptor made up to remove it and to fit my filter but want to know what effect it will have before I do anything
Old Jul 26, 2008 | 10:28 PM
trevCOSS's Avatar
trevCOSS
the downside is it will be restricted, however i, assuming thats its mapped to run the restrictor so it will need re mapping when you take it out.
Old Jul 26, 2008 | 10:29 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Why would you run a restrictor unless regs specified that you had to?
Old Jul 26, 2008 | 10:31 PM
Mr C's Avatar
Mr C
The turbo has one fitted at the minute as its Maram shafted ALS etc etc, Im planning to remove it ASAP but wanted to know how it would feel to drive with it on V with it off. Ive only driven the car once so far so cant compare till its on the road again
Old Jul 26, 2008 | 11:22 PM
NEEDFORSPEED's Avatar
NEEDFORSPEED
get it off and mapped!!
Old Jul 27, 2008 | 12:02 AM
J1mbo's Avatar
J1mbo
B1mbo
send it to harvey at scs and he will bore it out for you and should have a chip for you so it does not have to be remapped too !
and you keep the rally restrictor look which i think is ace!!
Old Jul 29, 2008 | 03:05 AM
jammy86's Avatar
jammy86
Restrictors limit ultimate power. remove it and remap.
JAmes.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Toe Knee
Aug 23, 2015 08:31 AM
IAN RS2k
Aug 18, 2015 07:51 PM
turbobill
Aug 9, 2015 05:21 PM
