Electric Window Problem
Does anyone know the best way to check if the windows relay is gubbed or no?
Started havin a few probs with them couple of weeks ago, different windows wouldnt work at different times then few minutes later itd be fine, now none of them are working. would that be the relay?
It is possible to dismantle and to clean inside. Carefully.
Regards.
Claude
tried that already, i have another set of switches.
they were working intermitently, drivers window wouldnt work then b ok 10 mins later, few days later itd be the passenger windows turn to play up.
now i have hee haw working
Smoke problem was : turbo shaft broken (1,6 bar is too much for a T3 !!!)
Regards.
Claude
Ouch about the turbo Claude - great video though
I had a problem with my rear window working on and off some years ago. Got everything apart connections-wise that I could. Never did find a fault but it did the trick as it was still working yesterday and it must have simply been a dodgy connection..
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
