Zetec bottom end
Old Nov 3, 2004 | 04:43 PM
K18NEO's Avatar
K18NEO
Default Zetec bottom end
How much are these and are they straight forward, off comes the bottom cvh, and on goes the zetec?
How much bhp you looking at ?
Old Nov 3, 2004 | 07:08 PM
K18NEO's Avatar
K18NEO
Old Nov 5, 2004 | 05:06 PM
K18NEO's Avatar
K18NEO
Old Nov 6, 2004 | 10:36 AM
orion_rs's Avatar
orion_rs
Check on this site: http://www.jimhearne.co.uk/zvh.htm
Old Nov 6, 2004 | 02:09 PM
rst230bhp's Avatar
rst230bhp
Heres another site to check out
www.edenperformance.co.uk
Old Nov 6, 2004 | 02:47 PM
Paddy rst's Avatar
Paddy rst
my 2.0 zvh has got 218 bhp at 13/14 psi on ke-jet injection..
expect a lot more bhp with management
you need to get a water pump plate so to fit the cvh water pump,
also the o/s engine mount needs to be slighty modded so the fixing bolt holes lign up correctly,think it just 1 hole that reqs modding..
c/head also has been modified to fit..
also get a 1.8 zetec sump and adaptor plate..
Old Nov 7, 2004 | 09:50 AM
K18NEO's Avatar
K18NEO
cool
Old Nov 10, 2004 | 06:25 PM
gavintwopies's Avatar
gavintwopies
ive got a 1.8 zvh in mine running 14psi with a scorpion exhaust and a k+n with no other mods and got 147 @ the wheels which is around 180 at the flywheel (ish)
Old Nov 10, 2004 | 06:27 PM
gavintwopies
paddy was that your s1 in this months fast ford along side chips and nathans cossie etc etc??
Old Nov 11, 2004 | 09:26 AM
S2zetec's Avatar
S2zetec
Its just as easy and cheap to build a zetec turbo with or without ke jet
Old Nov 14, 2004 | 09:56 AM
mkv_turbo's Avatar
mkv_turbo
can u run a full zetec on the ke jet system??
Old Nov 14, 2004 | 11:09 AM
Rossco's Avatar
Rossco
Do you mean a 16v Zetec turbo???
If yes it is possible but the main prob is fitting a dizzy to the Zetec, iam gonna use FRST management on my 2.1l 16v Zetec turbo
Old Nov 14, 2004 | 12:27 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
what needs doin to the head??
easy for a simple machine shop??
Old Nov 14, 2004 | 07:26 PM
mkv_turbo's Avatar
mkv_turbo
as above, might be an interesting alternative
Old Nov 14, 2004 | 08:29 PM
Rossco's Avatar
Rossco
What do you mean, nothing much if your planning on a 16v Zetec Turbo, could get it gas flowed, other than that it will need the studs for what ever manifolds you are gonna use drilling, easy stuff for any machine shop
Old Nov 15, 2004 | 07:37 PM
1.9 xr2 on 40's
st170 breaking
i meant for zvh
Old Nov 15, 2004 | 07:59 PM
1.9 xr2 on 40's
st170 breaking
ok seems head is fine for zvh, only issue i can see bar buyin the bits (whick im now sortin) is using a 1.8 bottom end and the compression being right
ne1 know if its ok? cant go changing pistons cos its gonna get pricy then and i just want to do it as a cheap option
cheers
Old Nov 16, 2004 | 11:54 AM
Rossco's Avatar
Rossco
compression ratio is way to hight for a turbo to run any serious boost, low comp pistons is they proper way to do things, other wise a decompression plate from fridey (spelling) enginering would do the job.
Old Nov 16, 2004 | 01:01 PM
davidnormanuk's Avatar
davidnormanuk
Go to this site for decompression plates. Done 500 miles so far on my RS with one of these on and not had any problems (touch wood). Good bloke to talk to.
http://www.ferriday.co.uk/copper/copper.html
Old Nov 16, 2004 | 09:02 PM
1.9 xr2 on 40's
st170 breaking
do they need to be bonded to the block or sumthin mate(s)?
i would only want a bar of boost neways really, would std 1.8 handle that or deffo de-comp the way to go?
im being real tight on fittin the lump cos i have enuff other bits to spunk money on and want to pay out as little as poss
Old Nov 17, 2004 | 09:05 AM
Rossco's Avatar
Rossco
Yep thats who i ment, they dont need to be bonded to the block, they are just a thicker headgasket.
Old Nov 17, 2004 | 10:31 AM
1.9 xr2 on 40's
st170 breaking
a reusable 1 too?
Old Nov 17, 2004 | 12:43 PM
Rossco's Avatar
Rossco
Theres a big company review in Preformance Ford this month, they look like a proper company there to help ya out
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Tank Mike
Sep 10, 2015 07:56 AM
grishenko45
Sep 9, 2015 12:58 PM
BRAM
Sep 8, 2015 07:11 AM
natehall
Sep 8, 2015 05:13 AM
