PTS Chip & 3 bar map
The chip is a PTS L1 2wd cosworth item and ran T3, 803's and was wild in the car.
The map sensor is a Magneti Marelli 3 bar, in full working condition as the car was just set-up at MSD and worked, the pipe coming off the map is glued but like said works as it should.
Selling both together for £60 + £5 postage
