smoking when letting off the power
Old Jul 24, 2008 | 05:19 PM
mk3cab's Avatar
mk3cab
Default smoking when letting off the power
hi all i have a problem with the car smoking only when i let the throttle go, its fine when accelerating in boost no smoking at all as soon as i let off it smokes quite badly. what could this be.
matt c
Old Jul 25, 2008 | 11:05 AM
turbozvh's Avatar
turbozvh
i had this problem about 3 years ago and it was the crankcase oil filter changed it and no more smoke but ive just had the same problem again its been smoking for about a month i changed the filter but this time it wasn't the filter. the other day the car started misfiring and clouds of smoke coming out which ive been told is the turbo oil seals or turbo piston ring has let go. going to swap turbo from the missus car later to see if its the turbo ill let you know what happens
TPM961
Jan 15, 2018 10:50 AM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
Bransby
Sep 21, 2015 05:29 PM
turbowag
Sep 3, 2015 08:07 AM
