saff cossie 4x4 pas pump brackets
hi people im after the 2 pas pump brackets for a J reg saff cossie 4x4. I need the bracket that bolts to the engine and the bracket that bolts to the back of the pump. My engine has the 3 aux belts if that helps. My car had air con but it didnt work so i pulled all the air con system out apart from the air con pump. My cossie has had an after market air con system fitted at some time. I just wanna get rid of the air con pump now and put it back to normal. Just let me know if you have any spare. Thank you.
Danielbetty
Aug 23, 2015 08:25 PM
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
155lee
Aug 14, 2015 11:21 AM
