saff parts
Need
vibra technics engine mounts
vibra technics gear box mount.
door mouldings must be vgc
injectors [green]
injectors [green]
Need
17mm door plate. so can hang n/s/f door. goes inside A pillar.
rubber engine mounts the that bolts to cast mounts.
plastic triangle on rear door. [set]
door mouldings[set] must be vgc
full interior dark cloth preferred seats/door cards.
starter motor.
injectors [greens]
starter motor.
injectors [greens]
Got the mounts
Got the triangle set
Got a mint late spec dark cloth 1992
Got starter
PMSL trading NO answering a wanted advert YES
bedroom trader I wish then I wouldnt have to pay this tax bill my accounted has dropped on me plus his fees, now you should know better than that
