Charge Air Sensor
Old Jul 21, 2008 | 07:30 PM
cos jon's Avatar
cos jon
Default Charge Air Sensor
I've noticed that my SECS gauge is showing the charge air temp is constantly changing from about 14 deg to -40 deg when i put the ignition its like a random number generator !
I assume my sensor needs changing ?? all the connections seem to be ok ....
Old Jul 22, 2008 | 09:48 AM
grcossie's Avatar
grcossie
You probably have to change sensor yes. Here is a side to help sort out
http://www.siipicossu.com/manuaaleja...sis%20Info.pdf
Kind regards Geir Rune
Old Jul 22, 2008 | 05:34 PM
Kelv's Avatar
Kelv
Almost there!
is that purely with the ignition on but not with the engine running?
what does the air temp show on steady tickover and then driving?
Old Jul 22, 2008 | 08:15 PM
cos jon's Avatar
cos jon
With the ignition on and engine running too, mainly stays on -40 but does sometimes switch to other figures.
Bought a new one so hopefully that will sort the problem out.....
Old Jul 22, 2008 | 09:29 PM
Kelv's Avatar
Kelv
Almost there!
should only take 5 minutes to change so hopefully you will know soon.
Old Jul 30, 2008 | 01:31 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Could also be the wiring as this goes brittle with age and breaks, so replacing the sensor might not cure it and you may have to renew some of the cable.
Nov 1, 2015 06:53 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
