Charge Air Sensor
Charge Air Sensor
I've noticed that my SECS gauge is showing the charge air temp is constantly changing from about 14 deg to -40 deg when i put the ignition its like a random number generator !
I assume my sensor needs changing ?? all the connections seem to be ok ....
You probably have to change sensor yes. Here is a side to help sort out
http://www.siipicossu.com/manuaaleja...sis%20Info.pdf
Kind regards Geir Rune
With the ignition on and engine running too, mainly stays on -40 but does sometimes switch to other figures.
Bought a new one so hopefully that will sort the problem out.....
Johnny Knoxville
30-09-2015 07:21 AM
Russ Payne
25-09-2015 08:29 PM
