10/20mm inlet spacer
Old Jul 20, 2008 | 12:27 PM
S1Luke's Avatar
S1Luke
Default 10/20mm inlet spacer
i see a few resto threads on here and there adding these inlet spacers.
so can someone tell me whats the advantage's..
power/air
thanks guys.
Old Jul 20, 2008 | 12:56 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
power/air
thanks guys.
you refering to cossie ones IIRC they can increase torque. The only real size that doesnt require messing about trying to get the fuel rail to fit back right is 17mm. This is the exact size required to put the fuel rail on the back of the spacer and keep the angle of the fuel rail std.
Please seek clear advice from a tuner before taking my advice as concrete.
Dan
Old Jul 20, 2008 | 01:37 PM
S1Luke's Avatar
S1Luke
cheers fella..
i like the sound of more talk... but will check with tuner first...
Nov 1, 2015 06:53 PM
stephenb4506
33
Oct 2, 2015 06:25 PM
Fudgey
21
Sep 30, 2015 06:19 PM
mondeomark
Sep 28, 2015 06:28 AM
