help please guys !!!!
Old Jul 20, 2008 | 10:43 AM
webby80's Avatar
webby80
Default help please guys !!!!
picked up my new s2 last weekend , when i collected it i was told by the previous owner he had turned the boost down for better fuel econamy on the way down through scotland , the day after i got the car i noticed there was a slight little end rattle so whipped the engine out and fitted a spare i had . im now thinking he turned the boost down because he had blown it to fook ! problem i have now is what do i reset the boost to ? he has removed the amal valve altogether and fitted a bleed valve car is currently reading 0.4 bar with my spec engine what should i safely set it at and which way do you turn the screw ?
the engine spec is as follows - rebuilt 1.6 cvh piper 285t cam kit , hybrid t3 ,-31 , mongoose , k&n cone and ahmed bayjoo chipped ecu .
any ideas would be great guys thanks
Old Jul 20, 2008 | 03:29 PM
stephenbatey's Avatar
stephenbatey
Mine is running same spec as yours minus the cam and i run 15psi, but av had mine on RR to be set up. I would recomend you take yours to be set up properly mate saves any costly mistakes.(anti-clockwise to raise boost if you fancy it )
Old Jul 20, 2008 | 10:02 PM
bigchez's Avatar
bigchez
Webby, I bought your old S2 (E35 BHK) off you and had that set up with a big front mount intercooler to run 22psi. Running more boost will transform the car, just get it done by a tuner you trust (MSD are on your doorstep virtually )
OrionRST200bhp
Sep 29, 2015 08:30 PM
Fiddy
21
Sep 29, 2015 06:10 PM
`spotty
Sep 25, 2015 11:41 PM
davidfordrs
Sep 21, 2015 04:23 AM
Rizlablue
Sep 6, 2015 09:58 AM
