3dr speedo not working
Old Jul 20, 2008 | 07:58 AM
Rs(555)'s Avatar
Rs(555)
Default 3dr speedo not working
as above .. if i unbolt cable off side of box will oil go everywhere?? do you test it with a drill attatched ????
Old Jul 20, 2008 | 10:02 AM
DD's Avatar
DD
if its just the cable your taking off the gearbox, then no oil will come out...if you take the speedo drive out then yes oil will come out.
a drill should test the cable ok.
Old Jul 20, 2008 | 10:12 AM
LHD220Turbo's Avatar
LHD220Turbo
as above, if you take the speedo drive out then yes, oil will piss out; but where is a clip which fits inside the drive that hold the drive in, pinch it together with a suitable tool and that will allow you to pull the speedo cable out
Old Jul 20, 2008 | 11:03 AM
If you jack up the car(rear) they do not lose much, this is how I did it.
Old Jul 20, 2008 | 01:11 PM
Rs(555)'s Avatar
Rs(555)
thanks all ...i took the speedo drive out then removed it from cable tested with drill and worked fine put it all back together ,just been down the road in in and the speedo and mileometer work now !!!!!!!! whats all that about just hope it lasts now
CLIVE
Oct 2, 2015 12:58 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
Escortdriver1
Jul 31, 2015 02:36 PM
