RS Turbo (S1) racing gearbox
Old Jul 19, 2008 | 07:43 PM
jamseju's Avatar
jamseju
Default RS Turbo (S1) racing gearbox
Hello,
First of all cheers for everybody as I´m new here.
I have a gearbox which I believe is from Ford Escort Mk3 RS Turbo S1 (circuit) racing car. It is a 5-speed dog engagement gearbox with viscous LSD. Originally it has a cable clutch.
Now the gearbox is broken and I´m very keen to have some information about it. Manufacturer? Model?
Here is some pictures of gearbox to be identified:
JJ
Helsinki,
Finland
Old Jul 19, 2008 | 07:50 PM
gus's Avatar
gus
looks very similar to the one i have
hewland af100 straight cut dog box
but there are some differences
here is mine
and yes sir they are rare, do you have someone who can rebuild it for you?
Old Jul 19, 2008 | 07:51 PM
gus's Avatar
gus
do you have any other parts for it?
Old Jul 19, 2008 | 08:07 PM
gus's Avatar
gus
what car did you get it from? few odd bits like the front mount and starter motor location
do you have any more pics of the hydralic clutch conversion?
Old Jul 19, 2008 | 08:08 PM
jamseju's Avatar
jamseju
Nice! That is same gearbox The gear linkage in my gearbox is "home-made" because there was no linkage when I bought it. Do you have pictures of the linkage?
Yes, I have one extra CWP (~4.2:1) and one viscous LSD (no oil). And in Finland we have manufacturer which make gears for that gearbox. And those are left-overs....
Actually everything inside is OK but the bellhousing (shown in pictures) is broken. Do you know any place where to get one of those? I´m also interested other (spare)parts..
JJ
Helsinki,
Finland
Old Jul 19, 2008 | 08:18 PM
gus's Avatar
gus
no sorry, i could of helped with gears but i do not know of any spare bell housings
no pictures of my linkage yet, mine is home made and im not liking it. i will get a quaife set up for it when funds allow. i will get a pic of my linkage in the morning when implaying with car
you are the 4th person i know with one of these boxes
i think they was used in both circuit and rallying
the shafts will need to be made for this as mine are alot bigger gearbox end and then use standard hubs
Old Jul 19, 2008 | 08:23 PM
jamseju's Avatar
jamseju
Actually gearbox is now in different car so the front mount and starter location are different.
Here is picture of hyd clutch conversion. It´s first version and now the bearing is different.
Old Jul 19, 2008 | 08:27 PM
jamseju's Avatar
jamseju
Which LSD do you have? Mine has Gemini (plate type) LSD and it´s originally from VW. So I use VW inner joints (OD 110mm).
JJ,
Helsinki,
Finland
Old Jul 20, 2008 | 10:25 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Ooooooh, get you two waving your fancy gearboxes around.
Old Jul 20, 2008 | 11:15 AM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Old Jul 20, 2008 | 11:19 AM
Bondy1's Avatar
Bondy1
I wonder if the stamp GSE is Gordon spooner engineering.
Old Jul 20, 2008 | 11:30 AM
Christian and Beccy
#1 in Spelling Club
Buy this and take the gearbox out of it.
http://www.pistonheads.com/SALES/580674.htm
Old Jul 20, 2008 | 01:29 PM
jamseju's Avatar
jamseju
I believe also that the stamp is from Gordon Spooner. Maybe the gearbox has been serviced / repaired there in the past.
I hope that there is some other way to fix my gearbox than buying that car. Because that car is very nice piece of rallying history. So it should be kept in on piece.
JJ
Helsinki,
Finland
Old Jul 20, 2008 | 02:34 PM
gus's Avatar
gus
you not got one then mr c?
Old Jul 20, 2008 | 09:45 PM
Christian and Beccy
#1 in Spelling Club
Errrrr, no. I'm just going through the aggravation of fitting an MTX.
Old Jul 21, 2008 | 02:49 PM
jamseju's Avatar
jamseju
Hi Gus,
Did you take pics of your gear linkage?
JJ
Helsinki,
Finland
Old Jul 21, 2008 | 02:55 PM
gus's Avatar
gus
i will get a pic now, will have to go home before i can upload thou as i not got the lead here
its very agricultural!!!! hence me wanting to change it
do you know which model volvo you got your hydralic clutch bit from? any mods to the bell housing (internally)?
Old Jul 21, 2008 | 03:48 PM
jamseju's Avatar
jamseju
It´s from V70 (petrol engine) year 2002. But there is similar cylinders in various Volvos..
It needs only little machine work inside housing to fit it. Oh, and you need base plate for it. Here is a foto of it...
Old Jul 21, 2008 | 04:09 PM
gus's Avatar
gus
this is my linkage, not the best pics but you get the idea
just need the quaife unit now!
Old Jul 21, 2008 | 04:43 PM
Christian and Beccy
#1 in Spelling Club
Nice trainers.
Old Jul 21, 2008 | 04:47 PM
gus's Avatar
gus
their the other halves, she got freakishly big feet
Old Jul 21, 2008 | 07:01 PM
cressy's Avatar
cressy
Old Jul 22, 2008 | 08:44 AM
cabrst's Avatar
cabrst
thats some nice Gbox
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
Gary @ RS CLASSICS
11
Sep 10, 2015 06:49 AM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
rsstav
Ford Focus ST Parts for Sale
Aug 11, 2015 04:19 AM
