3dr head lights help
Old Jul 18, 2008 | 07:50 PM
COLEYST200's Avatar
COLEYST200
Default 3dr head lights help
i need some help please with a small problem iv got with the lights on my 3dr when i put the side lights on only the pasenger light comes on so i put a new bulb in the drivers side still no good got the prob out and theres no + coming down the wire that powers it up so i fort i might run a wire from the pasengers light . i now its not right but it would make it work but the dashbord still has a light on to saying its out so i swopped the storks over and still the same dose any one think it could be one of boxes that live under the gove box as im at a los with this one at the mo
Old Jul 18, 2008 | 08:00 PM
PAUL S's Avatar
PAUL S
Are they new/ newish 3dr headlights. For some reason the new replacement 3dr ones came fitted with saff internal wiring which differ from the original 3dr ones. You need to to a bit of re-wiring inside the drivers side headlight if they are, as the passenger side on a 3dr is fed from it, unlike the saff ones which have independant feeds to both headlights from the main loom.
Ryan will no doubt know which wires to splice on the new type headlights as I cannot remember which way it was when I did it a while ago
The other easier option is to take the little internal looms from inside an old pair of 3dr headlights and put them in the new ones, this way they then match the 3dr loom and will work fine
Old Jul 18, 2008 | 08:08 PM
COLEYST200's Avatar
COLEYST200
I can see wot your saying but when you put a prode in the plug on the loom with the plug out of the light there is no power when i unplug the pasenger side there is power coming down the wire which to me says its a fead problem not the lights
Old Jul 18, 2008 | 08:11 PM
COLEYST200's Avatar
COLEYST200
O i forgot the wire on the divers side is gray with a red line and the pasenger side is gray with a black line so im thinking there two feads to the lights
Old Jul 18, 2008 | 09:07 PM
Ryan's Avatar
Ryan
have you got all the earths on the front chassis legs? (either side of where the intercooler sits.)
Old Jul 18, 2008 | 09:35 PM
COLEYST200's Avatar
COLEYST200
yes mate they all look good
3dr cossie
21
Nov 20, 2015 05:00 PM
Bailes1992
Sep 3, 2015 02:17 PM
mint_s2
Sep 2, 2015 08:58 AM
IAN RS2k
Aug 18, 2015 07:51 PM
