fuel pump 3dr
Hi lads i need some help please im rebilding a 3dr and have had to sores a lot of stuff and as iv never had or worked on a 3dr befor im lerning all the time with this car . right we had to by a 3dr loom for the car and all the relays were missing so we have done awer best to try and sort them out but the thing is we dont seem to be abull to get any volts to the wires that fead the fuel pump. Dose it have a relay for the pump and if so were is it and wot dose it look like . And as we on about it can any one put a photo of the fuse box so i can see wich ones go were THANKS
its a four pin jobby in yellow if its still the ford one, that lives around the ecu area...not attached to a board or owt, just floating around along with the amal valve relay.
Thanks mate iv now sortid it . this is wot was rong .......i had posted it in genral page to
RIGHT then thanks to your help iv just sorted it. when we got the car we had to do a hot wire to the pump to get it to run but that was no serprice to us as all the wiring was shit . so out with the old and in with the new but we are using the old motor loom BUT i did have the sens to send it down to RYAN at CAR LOOMS UK and he went over it and sorted it all out for me . when you lot were telling were to look i rememberd RYAN saying to me that i had got to run a live wire to a plug wich i have done but still no working pump so i put a probe on the wires and got it to work so now wots rong . then i fort it must be controld from the ECU and the ECU i was trying was the the one that come with the car so i got my spair put it on and i now have a pump that works . sothe problem was a + wire and a FUCKED ECU
JK12
33
Apr 26, 2021 12:09 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
