I need rear wheelarches for my escos
Anyone know if there are places i can get just the arches? I know atmsport has complete rear panels, but i only need the arches. Actually i just need the right one but ill take both if i can.
Try Jack (www.cosworth.nl) or/and Wolf (http://www.wolf-performance.com/).
Maybe they can help you out
I would suggest that a 'Good' bodyshop would be able to fabricate small body parts like arches.
My mate had his Lotus Carlton rebuilt, Lotus fabricated all the arches themselves on the production line and did't bother making any spares so he had no choice but to have everything fabricated. The finished job was much better than the factory quality!
Paul
Paul
If you have rust around the filler cap, then I would recommend replacing the whole 1/4 panel regardless as the rot will be where you cannot see it. Once repaired, it will only find a way back where as a 1/4 panel means a better-finished and (hopefully) longer-lasting job even if it does mean taking longer.
you can normally get away with one of these for the fuel cap area
http://cgi.ebay.co.uk/Escort-Mk5-XR3...3286.m14.l1318
Actually just got one of those in the mail today. So only thing i need now is the rear arch. I also thought of changing the whole panel, but its really small rust spots and no holes on the back side if you understand.
155lee
Sep 6, 2016 11:10 AM
The Enigma
Sep 12, 2015 10:12 PM
