2wd sapphire running and starting problem
Old Jul 17, 2008 | 12:12 AM
scott_j166's Avatar
scott_j166
Default 2wd sapphire running and starting problem
hello wonder if anybody can help me before i start changing bits on it,when starting it it sounds like its running on 3 when it fires up then clears and sometimes when starting it it just keeps turning over for a while before firing up.cheers
Old Jul 17, 2008 | 02:51 PM
mechanic28's Avatar
mechanic28
i would start with a set of plugs/cap and rotor arm!is this from hot or cold?
Old Jul 18, 2008 | 12:27 AM
scott_j166's Avatar
scott_j166
it does it from hot and cold,it always seems to do it when its sitting ticking over then for the first few seconds when giving it some revs it sounds like its running on 3 then clears but will give them a try mate cheers
Old Jul 18, 2008 | 10:35 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Also make sure the leads are firmly connected at each end
jason_nike
Aug 18, 2019 10:53 AM
saph in dorset
Aug 14, 2015 10:10 AM
Zoggon
Aug 10, 2015 10:39 AM
ginger1979
Jul 31, 2015 09:56 PM
Old ford
Jul 31, 2015 06:50 AM
