fourbie saph stage 3 ?
Old Nov 2, 2004 | 03:03 PM
slowpoke's Avatar
slowpoke
Default fourbie saph stage 3 ?
what does it consist of ?
i know t34 ideally and the normal stg 3 stuff but what head gasket is recomended ? swirl pot ? extra oil breather ?
any opinions on the above please
matt
Old Nov 2, 2004 | 03:14 PM
JamesH's Avatar
JamesH
wire ring the block and use a std head gasket (Ł8!)
Old Nov 2, 2004 | 04:19 PM
TIFF's Avatar
TIFF
Chasing Radders
WRC Mountune 4 layer Head gasket--Do it once, do it right
Old Nov 2, 2004 | 04:23 PM
Smit's Avatar
Smit
The 60ft Launch King
Matt - I've got a stage 3 fore be fore
Got a T34 blower using a Group A headgasket which i've not had a issue with...
but if you can stretch a bit further then go for the WRC jobby (as winker above says ) think they are made by mountune??? might be wrong....
as i remember a conversation a while saying they were quite good
hth
Old Nov 2, 2004 | 04:27 PM
TIFF's Avatar
TIFF
Chasing Radders
Old Nov 2, 2004 | 04:32 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
I thought wire-ringing was not recommended any more. <- not meant to start heated discussions.
Old Nov 2, 2004 | 06:44 PM
slowpoke's Avatar
slowpoke
them 4 layer wrc gaskets are fookin dear tho yes ?
no one recomend a cometic one then ?
Old Nov 2, 2004 | 06:46 PM
TIFF's Avatar
TIFF
Chasing Radders
I PERSONALLY wouldnt touch a Cometic one as i have had a problem with them and a damaged engine
BUT
There are people who swear by them
Yes the WRC ones are expensive at Ł370 but you pay for what you get
Old Nov 2, 2004 | 06:48 PM
slowpoke's Avatar
slowpoke
fook tiff thats a lot of money for a gasket only runnin stg 3 power !
how much dosh you reckon to properly change the head gasket ?
Old Nov 2, 2004 | 06:51 PM
The Gravedigger's Avatar
The Gravedigger
Can someone explain what wire ringing is? Must have heard the term a thousand times without actually knowing what it meant
Old Nov 2, 2004 | 07:26 PM
Sticky.'s Avatar
Sticky.
matt make your own....Cornflakes box & some gasket sealer should do the trick
Thats what Tiff is using, but when he say's Multi layer, thats all the big mac boxs he's been saving
Just for you mate
Old Nov 2, 2004 | 07:27 PM
TIFF's Avatar
TIFF
Chasing Radders
You fookin coont
Old Nov 2, 2004 | 07:28 PM
Rhys's Avatar
Rhys
I run cometic! Though i was under impression they suit a car with long studded block etc Though i might be talking bollocks
Old Nov 2, 2004 | 07:34 PM
Sticky.'s Avatar
Sticky.
Originally Posted by TIFF-C20WTH
You fookin coont
Sorry mate, i thought everyone new, but i'll keep the secret about the standard inj painted grey
Opps did i say that out loud
Old Nov 2, 2004 | 07:36 PM
slowpoke's Avatar
slowpoke
so cometic no good for a std stud type engine then ?
stu's input in this would be good as i think he recomends cometic gaskets
Old Nov 2, 2004 | 07:37 PM
TIFF's Avatar
TIFF
Chasing Radders
Yes, Stu uses Cometic
Old Nov 2, 2004 | 07:42 PM
Cossiep's Avatar
Cossiep
No probs with Cometic's but I do agree if the pennies can stretch go with the proper WRC item I ran a cometic jobbie with no probs and also remember they come in two thicknesses
Old Nov 2, 2004 | 09:17 PM
slowpoke's Avatar
slowpoke
so cometic head gaskets are better than grp a ones yes ?
Old Nov 2, 2004 | 09:28 PM
Dilly's Avatar
Dilly
standard 4x4 gasket is alright for stage 3
Old Nov 2, 2004 | 09:47 PM
RichardPON's Avatar
RichardPON
If you stick a WRC gasket on a cossie at Stage 3, you're either a moron, or you've got more money than sense.
What exactly is a Ł400 WRC gasket going to do, that a Ł60 "Group A" one isn't?
Matt - my feeling is this.
Go stage 3 with greens, chip, and 3 bar, and run the T3 at a reasonable level of boost.
Prepare for the headgasket to go at any time, as it could, and be prepared for the turbo to let go, as it could being old (probably)...........
Put a decent aftermarket oil breather on the car anyway, as the std. Ford one is pants, and if you like bling things, then put a swirl pot on.
I've run my car on a Group A gasket for four years, and people have seen how I drive my car - never a hint of a problem.
Old Nov 2, 2004 | 10:26 PM
slowpoke's Avatar
slowpoke
thanks pon helps me a lot that does
ive got a t34 or i w ill have very soon so thats that bit taken care of
my rocker cover is powder coated, my question is can you drill through the powder coat without it all cracking and looking a right mess ?
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
A.t.p
Sep 29, 2015 05:04 PM
