Horn problem 2wd saff
Old Jul 16, 2008 | 07:14 AM
bpspa's Avatar
bpspa
Default Horn problem 2wd saff
Well the saff has been sitting for the last 4 months, finally got it out of the garage at the weekend, but every now and again the horn would just go off by itself just a short little blast, only seemed to happen when turning the steering wheel.
Any ideas on what the problem is, earth related????
Old Jul 16, 2008 | 11:44 AM
rickbartlett's Avatar
rickbartlett
G911 TTA
2 wires must b touching in the steering wheel mate
Old Jul 16, 2008 | 11:55 AM
cozmeister's Avatar
cozmeister
More boost Igor!
Pop the horn push out with a small screwdriver and refit it - that might be all it needs. While it's out, check that the earth wire's not able to short itself anywhere it shouldn't.
Old Jul 16, 2008 | 12:58 PM
gaz4x4cos's Avatar
gaz4x4cos
had same prob for mot ,intermitent i thought it was the push too n it was the earth on the horn on one side and other had packed up completely ,
took it off cleaned with a wire brushed , bit of copper grease , new bolt n it works fine now .
just unplugged the wire on the none working one and left off .
hope this helps m8 .
Old Jul 16, 2008 | 03:28 PM
bpspa's Avatar
bpspa
cheers guys will do both as suggested
James Porter
Oct 28, 2015 12:17 PM
FlashRS
13
Aug 31, 2015 06:02 PM
mrmann
Aug 20, 2015 11:24 PM
Old ford
Jul 31, 2015 06:50 AM
