rear arms Pics from 3dr cossie,wanted
Hello,can anyone put here some pics from 3dr the rear arms without wheels because i want to see the brackets for rear anti roll bar,will be help so much,thanks a lot
Thanasis
Thanasis
I'll get some piccies of me dads xr4i arms later today as same arms, but arb bit on arm same as sapphy arms just different place as in on the outside edge of arm instead of inside edge.
Not sure if this is any help but the arb is in the back of the van and the clip is hanging off it at the bottom - it fits on the trailing arm bracket which can also be seen... its just forward of the disc cover.
The xr4 arms have the arb mount in the same place as the 3dr, but wont have the hole for the abs sensor by the hub and have rubber bushes rather than spherical bearings, if thats not an issue to you then they can be used as an alternative
155lee
Sep 14, 2015 07:37 PM
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
