idle raises on car when hot?
Old Jul 10, 2008 | 07:38 PM
rst in breaking's Avatar
rst in breaking
Default idle raises on car when hot?
ive had my car running for a small time now on my zetec turbo, problem im noticing is when the engine warms up after say 15mins, the idle rises? im running emerald management and was told the idlespeed control valve was intergrated in the ecu? im thinking i need the base map checking over but have not m.o.t so cant drive it anywhere atm. The other problem being is once really warm the car doesnt want to rev to drive? but will tick over fine? really puzzling me now so any help much appreciated
Old Jul 10, 2008 | 08:59 PM
rst in breaking
anyone?
Old Jul 10, 2008 | 10:04 PM
gup's Avatar
gup
alright fella did you check your plugs
Old Jul 10, 2008 | 10:09 PM
rst in breaking
yes mate, all burning rich, but all 4 working
Old Jul 10, 2008 | 10:20 PM
gup's Avatar
gup
ah you could try and lower the c.o and c if that helps the idling
also what was the alt reading again
Old Jul 10, 2008 | 10:27 PM
rst in breaking
on the volts gauge its reading 12ish, but dont think its taking charge and batt light is on on the clocks suggesting alternator but ain done any checks yet. problem with adjusting the c0 is i need someone who knows what they're doing as the car ain too drivable and nobody will travel, chip was going to do it but need m.o.t which i cant get till car runs better
Old Jul 10, 2008 | 10:31 PM
gup's Avatar
gup
ill pass that number to ya fella for winston he can set the c.o for you
Old Jul 10, 2008 | 10:34 PM
rst in breaking
nice one, i think the throttle position need setting too poss
kosienutter
31
Aug 22, 2015 09:55 AM
dojj
Aug 12, 2015 08:52 PM
Adam-M
22
Aug 10, 2015 10:46 AM
Zoggon
Aug 10, 2015 10:39 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
