Ball&Spring style bleed valves (dawes?)
This is for those with first-hand experience of using normal bleed valves and the ball&spring locker type... sometimes called dawes devices (sheep mode)
I think chip you've used one of these?
Basically do the ball&spring valves give you a linear increase in boost? I'm trying to think of a cheap and nasty way to do it.. Need to increase from say 3psi to 7psi across the powerband.. only a small turbo, perhaps a T2 or GT15 type thing.
I've used a gated bleed valve & normal vent bleed valve.
I used the Dawes Device on my GT35 & was very good at increasing the boost a lil bit at a time as the dial is on a rachet so jus go a couple clicks at a time !!
Mine broke tho !!
Hope this helps
jb
Mine broke tho !!
Hope this helps
jb
SMILER258
Sep 28, 2015 09:04 AM
