cutting braided hoses
as per the goodridge type stuff.
i picked up 10 metres of ptfe lined hose today for the fuel system, and gonna start cutting it to length tomoz.
so whats the best way?
wrap the part to be cut in masking tape, hold in a vice, and then crack out the angle grinder?
should do it no?
should do it no?
yes thats how i cut the braided fuel hosing to my zetec rail when i had my zetec in. Be carefull though - the steel wires are very sharp and will prick you like mad....
should do it no?
should do it no?
on fine braided stuff like ptfe i use a dremel with cutting disc to get through the metal then a stanley knife to cut the pipe,just have to watch it doesnt fray,as the fittings will be a bitch to fit.
or use a dremmel type instrument to cut them
the tape will stop the ends from poking out and yes, when they stick you, it will hurt like fuck
but they also keep the ends tidy so that you can mark where you want to cut and keep everything together
i found that the angle grinder method is better than the hand saw method but i have also used a bit of pipe inside to stop the hose from deforing when you are half way through teh cut
Earls have a few videos on youtube demoing methods.
I havent used it myself, but they say to set the hose on some soft metal ( Alu etc ) and whack the damn thing with big hammer and a sharp chisel !!!!
http://youtube.com/watch?v=u1J7u8sG118
masking tape and hacksaw.................tried everything else.
used dremel if it went wrong i.e to tidy up the frayed bits.
BTW you will make a mess of your hands
I found cutting it with the grinder and a nice 1mm disk gave the best result every time, hacksaw worked but was easier to muck it up and make the fittings harder to assemble. Having said that mine was 200 hose not ptfe so it may be different
luke, im not using quip, doing it on the cheap remember lol
simon, cheers fella, you can see from the cut ends thats in been ground
totb-3 yeah i realise that it will get shit inside, i got an air compressor, but i think the chisel method is sounding like a goer
maybe get time tomoz to have a go
