2wd rear axle shims
Old Jul 9, 2008 | 07:38 AM
Basky's Avatar
Basky
Default 2wd rear axle shims
any pics and know who sells them.
Old Jul 9, 2008 | 08:04 AM
R5FORD's Avatar
R5FORD
check my sigg for who's website to go onto.
Old Jul 9, 2008 | 08:05 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
They are the thinest bit of metal known to man. I have zero idea how they actually do anything or what it is they adjust, but i put them on as Mike is handling guru and i do what he says
Old Jul 9, 2008 | 08:40 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The don't alter camber, but give the car toe-in, which makes it much more stable, especially when sliding the car . The standard factory settings are supposed to be parrallel, but with bush deflection / old worn bushes, this goes to toe-out, which makes Cossies feel REALLY unstable and they "tank-slap" if you lift off the throttle. With toe-in, the car is always trying to self centre, so a slide can be controlled progressively with opposite lock .
Old Jul 9, 2008 | 09:30 AM
Roosie's Avatar
Roosie
500bhp Cosworth in making
how much are these shims mike
Old Jul 9, 2008 | 09:44 AM
KSA-Cossie's Avatar
KSA-Cossie
See the website for prices.
Old Jul 9, 2008 | 09:45 AM
Mike Rainbird
Caraholic
A whole Ł10 inc delivery .
Old Jul 9, 2008 | 10:31 AM
CossieRich's Avatar
CossieRich
Mike,
I assume when a decent rear beam is put on, the shims can come off?
Old Jul 9, 2008 | 10:34 AM
Mike Rainbird
Caraholic
Yes, as you can dial in the toe with an adjustable 6° rear beam .
Old Jul 9, 2008 | 10:59 AM
Dingy's Avatar
Dingy
This makes me piss...
These are the biggest waste of time ever.....
Old Jul 9, 2008 | 11:14 AM
CossieRich's Avatar
CossieRich
why ding?
Old Jul 9, 2008 | 12:14 PM
Dingy's Avatar
Dingy
Why indeed....
saff's are not the straightest cars in the world from the factory...
The person that sets my car up laughed at the idea.....
Just Take the car to be setup by someone who knows about suspension and i mean an expert
Old Jul 9, 2008 | 12:27 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
Originally Posted by CossieRich
why ding?
cos ding has an atlas axle lol
however saying that paul bailey gave his atlas toe in but he didn't use sapphire shim plates lol
Old Jul 9, 2008 | 12:44 PM
Dingy's Avatar
Dingy
Requires heating up the tube LOL
Old Jul 9, 2008 | 12:46 PM
CossieRich's Avatar
CossieRich
Mike is about as close to an expert as you can get regarding cosworth handling Dingy.
Old Jul 9, 2008 | 12:48 PM
Lambchop's Avatar
Lambchop
PF Idiot Sniper
lol i cant wait for the reply to that
Old Jul 9, 2008 | 12:52 PM
Dingy's Avatar
Dingy
Right...
well the person that sets up my car does lemans cars and wrc cars... Can mike set up the suspension on these - erm NOPE....he doesn't have the facilties to set up suspension.
Old Jul 9, 2008 | 12:53 PM
CossieRich's Avatar
CossieRich
damn,
the reply wasnt as hardcore as i thought. Dingy must be softening a little around the edges
Old Jul 9, 2008 | 12:54 PM
Turbosystems
Super Moderator
Right...
that doesn't mean that mike doesn't know what the best settings are for a sapph
I feel the love dingy has for mike here,does anyone else feel it or is it just me
Old Jul 9, 2008 | 12:55 PM
CossieRich's Avatar
CossieRich
Right...
He may not have the facilites granted, but that doesnt mean he doesnt know HOW to set up a cosworth correctly. There is a difference in having thousands of pounds worth of tools to do the job and the knowledge to be able to do it.
Old Jul 9, 2008 | 12:59 PM
Mike Rainbird
Caraholic
Ahmed / my own experience has taught me everything I know. And obviously my Cossie handles like shit .
A race engineer will advise toe-out, as racing drivers will suffer instability for better turn in. I personally would not want to drive a Cossie on track set-up like this .
Old Jul 9, 2008 | 01:08 PM
R5FORD's Avatar
R5FORD
ok im confused.. do these straigthen the wheel when you look from the rear.. as mine go off at a fucked up angle
Old Jul 9, 2008 | 01:12 PM
Dingy's Avatar
Dingy
pmsl
Old Jul 9, 2008 | 01:13 PM
CossieRich's Avatar
CossieRich
So Dingy, what do yu have to say about that mate?
Old Jul 9, 2008 | 01:14 PM
abdr500's Avatar
abdr500
so do mine
Old Jul 9, 2008 | 01:15 PM
R5FORD's Avatar
R5FORD
Dingy give me your best shot
Mike1's Avatar
Mike1
Surely that's camber ( probably -ve ) you're seeing rather than toe?
Old Jul 9, 2008 | 01:16 PM
Mike Rainbird
Caraholic
Here is the article that I did for Fast Ford, which explains the ins and outs of Cossie suspension. Obviously I know Jack-shit though .
One of the worse suspension misconceptions that I see regularly repeated on bulletin boards throughout the internet, is that the stiffer and lower a car is, the better the handling will be. Unfortunately, if it were that easy or true, we would all be driving cars that were basically enlarged go-karts! Obviously if our roads were billiard table smooth, then there would be no issues and we could run higher levels of stiffness. However, we live in the UK where our roads resemble the surface of the moon at worse and subsiding, lorry ridged motorways at best!
So how exactly do you make a Cosworth handle? I really need to briefly give an explanation of the common technical terms that you will see or read about in all suspension development:
Camber: Is the angle of the wheel relative to vertical, as viewed from the front or the rear of the car. If the top of the wheel leans in towards the car, it has negative camber; if it leans away from the car, it has positive camber.
Caster: Is the angle to which the steering pivot axis is tilted forward or rearward from vertical, as viewed from the side. If the pivot axis is tilted backward (that is, the top pivot is positioned farther rearward than the bottom pivot), then the caster is positive; if it's tilted forward, then the caster is negative.
Toe: When a pair of wheels is set so that their leading edges are pointed slightly towards each other, the wheel pair is said to have toe-in. If the leading edges point away from each other, the pair is said to have toe-out. The amount of toe can be expressed in degrees as the angle to which the wheels are out of parallel, or more commonly, as the difference between the track widths as measured at the leading and trailing edges of the tires or wheels. Toe settings affect three major areas of performance: tire wear, straight-line stability and corner entry handling characteristics.
Bump steer: Is when the wheels steer themselves without input from the steering wheel during vertical suspension travel. The undesirable steering is caused by bumps on the road surface interacting with improper length or angle (or both!) of your suspension and steering linkages.
Roll centre:The point in the transverse vertical plane through any pair of wheel centers at which lateral forces may be applied to the sprung mass without producing suspension roll. In effect, it’s the virtual point about which that end of the body pivots about during roll.
Understeer: Where the front tyres don't follow the trajectory the driver is trying to impose while taking the corner, instead following a larger radius trajectory outside of the corner.
Oversteer: Where the rear wheels do not track behind the front wheels but instead follow a larger radius (or even slide out) toward the outside of the corner.
Bump: This is what the suspension travel is called when the car body is moving down towards the wheels
Rebound: This is what the suspension travel is called when the car body is moving up away from the wheels.
Next you need to understand the inherent problems that the Cosworth was lumbered with by Ford’s bean counters, by skimping on better suspension geometry, (and partly due to ignorance) to enable them to undercut rivals in the showroom. The 3-door has the best front end suspension set up for Motorsport, where it has a lowered TCA mounting point on the front suspension upright, and thereby effectively raises the front roll centre, improving turn in and resistance to roll. BUT this does cause some loss of stability due to the nervousness this in turn creates, which was the whole reasoning as to why the Sapphire had it's front roll centre lowered to keep the average car driver happy, as they no longer had to consider homologation for Motorsport use, due to the Sapphire being aimed at a mass market, rather than being a homologation special like the 3-door was!
With the 3-door (or a Sapphire 2wd fitted with 3-door
uprights and TCA’s), you can lower the car an inch at the front and the roll-centre drops by about 3 inches, which results in a very nice handling vs stability compromise. You can deduce from this, that lowering a Sapphire by even an inch at the front, has catastrophic effects on the roll centre placement and with further lowering, it often ends up BELOW ground level! In addition all Cosworth variants (in particular the 4x4s) are badly balanced by the standard 18 degree semi-trailing arm equipped rear!
What this creates is a large disparity in front to rear roll centre height, which results in a heavily inclined roll axis, and the rear suspension has a lot of bump steer, (which is the main cause for the inherent ‘push-on’ understeer that Cosworths are plagued with and very little to do with the front end geometry as is a popular misconception). Combine this with the very short virtual swing-arm length of the rear suspension geometry and it results in an unstable setup, with relatively large changes in toe, track and camber for its suspension travel, which is not good!
So ideally, before you even think about changing the dampers and springs, you really need to tackle these problems first. Fortunately there is a cure, unfortunately it is expensive, but if you don’t address this issue, everything else you do will still leave the front and rear axles fighting against each other.
When Ford developed the Cosworth, it was to go racing and rallying in both Group A and Group N categories, which as most people know is what the Cosworth 3dr hatchback and RS500 was designed, built and homologated for. The Group A rules allowed the pick-up points for the suspension to be moved by up to +/-20mm (the RS500 had the benefit of an added optional inner front semi trailing arm mounting bracket in production that gained an additional 60mm!) that allowed Ford to develop a revised semi-trailing arm geometry set-up that improved overall handling, traction and stability by keeping the tyres squarer to the road than the standard set-up! These Motorsport designed rear beams reduced the bump steer, camber change and improved the front to rear roll centre disparity by legally (according to the homologation rules) running lower semi-trailing arm angles of between 16 to 9 degrees! The RS500’s had a big advantage here with the cunning addition of that extra bracket fitted to the production car allowing the Group A rules to be exploited accordingly!
A road car fitted with a low angle (6 degrees in my case!) rear beam is much more resistant to under-steer, has much better traction and straight-line stability, and is fully adjustable for camber and toe (where the original beam is fixed). Fortunately for us, one of the team involved with the development of the Cosworth for racing/rallying, is still producing a fully optimised rear beam, (as in, that the semi trailing arm angles are positioned for optimal geometry without any Group A rule limitations!) to this day and it can be purchased from Ahmed Bayjoo for Ł1,000.00.
Only now are we ready to move on to the normal suspension components. Obviously everything that you do for a car that shares it’s usage with both road and track needs to be a sensible compromise, if its too hard, it will lose all ride quality and sometimes grip on the road and if its too soft, it will not have sufficient roll control on the track. For it to handle satisfactorily on the road, the first rule of thumb for any suspension system, is that the tyres have to stay in contact with the surface in order for them to provide the necessary grip that is required of them. Obviously on a typical bumpy road, this instantly precludes suspension that is too hard. Unfortunately, it would seem that the majority of the suppliers of aftermarket coil-over kits don’t seem to understand this and supply dampers with spring rates that are notably far too stiff, especially on the rear - and this is just the “show & shine” kits. Even worse, all the budget items are really only ideal for this type of show environment (as is openly admitted by these manufacturers), due to them having fixed bump settings and only a limited range of rebound.
In view of this, you’ll probably be surprised to learn that for an occasional track day car, that I would recommend that you stick with the normal Koni dampers that the majority of Cosworths are already equipped with. However, the crucial thing to achieve Cosworth handling Nirvana, is not to fit budget springs. His name has already been mentioned, but it might surprise you to know that one of the most respected engine mappers in the country, is also as knowledgeable about suspension design as he is ECU software. To that end, Ahmed has designed some springs that he has had specially wound by LEDA, that are specifically matched to the Konis – available in either fast road or track spec, they only lower the car by 10-15mm and give a perfect ride quality / handling compromise.
Also, it is crucial that the suspension isn’t plagued with too much movement, as that will also give bump-steer, so I always recommend that people taking to track should replace the original bushes with some polyurethane items (with the exception of the original Ford trailing arm bushes, which are rose-jointed and should not be changed on a road car, or if they are, too much noise and vibration is transmitted through the chassis, to the extent that you can’t see out of the rear view mirror at certain rpm points!). I personally recommend Powerflex, as they are very good quality and seem more durable than cheaper options.
For those more dedicated track people, the adjustability of a coil-over kit is probably more suited to a more aggressive driving style, with the benefit of easily being able to fine tune the set up (with some time and effort),including allowing the car to be corner weighted for optimum balance (this is where the ride height on each corner is adjusted to shift the weight balance around the car to try and give as close to even balance from front to rear and left to right). This is the route I have gone down and it has taken me a long while and several different spring sets to get the car to handle how I want it to. I opted for LEDAs as the range of adjustment far exceeds the budget set-ups that most people chose (despite these companies also offering track biased systems that are of equivalent quality, price and damping range to the LEDAs).
Where I have strayed from the norm is to go for spring rates that are compromised to a road and track environment. Luckily I had almost got my Sapphire to the point where I wanted it and so I knew that the springs had to be of a lower poundage than the Sapphire. Even so, I still met resistance from the technical people at LEDA and had to be forceful in persuading them that I was sticking to my guns with my choice of much softer spring rates than they considered being ideal.
Luckily my convictions were proven, as on the softest settings the LEDAs were as compliant as my four year old Konis were on their hardest, which mean that the car was a joy to drive on bumpy back-roads (something my Sapphire was never comfortable with) and on the track the car felt absolutely planted with it’s attitude being able to be controlled with the throttle. If you go into a corner too fast and it starts to run wide, the briefest of throttle lift will make the front tuck in. The car is totally neutral – just how I like it. The grip became so good that I was suffering severe tyre wear on the outside edges of the tyres, especially the front; where the tyres were basically scrap after a track-day due to this excessive wear, but the rest of the tyre was perfect. I realised that my driving style required a lot more camber, so after checking out the geometry settings in the Grp A build manual for the Escort, I noticed that these cars run extremely aggressive camber settings when on tarmac. Unfortunately, the standard front end TCAs are incapable of providing settings this aggressive, so adjustable ones had to be sourced. This completed my car’s set-up and as many of you will have seen, despite running treaded road tyres, it always punches above its weight at track days.
Fast Road Geometry settings:
Front: 1.5° negative camber, 2mm toe-in.
Caster as close to 3’30° as you can get.
Rear: 1.5° negative camber (not adjustable on standard rear beam, but will normally be around this depending on ride height), up to 3mm toe-in (using shims or by slotting the mounting points and tack welding the beam in position after welding – as per the Grp N cars).
Track day Geometry settings (you will need adjustable TCAs and rear beam to achieve these settings):
Front: 3° negative camber*, 2mm toe-in.
Rear: 2.45° negative camber, 3mm toe-in.
*Please note when running such aggressive negative camber on a track car that is 4wd, longer drive shafts may be necessary and also ball jointed top mounts are recommended, so as not to put excessive load on the damper tubes.
Thanks need to go to Ahmed for all his help and advice over the years in helping me understand the critical necessity for good suspension and without whose help, this article would not have been possible.
R5FORD's Avatar
R5FORD
ok il do a diagram..
my wheels dont look like this from the read | | they look like this / \
CossieRich's Avatar
CossieRich
its the tiger stripes making that happen. BIN THEM
Old Jul 9, 2008 | 01:17 PM
R5FORD's Avatar
R5FORD
so from my diagram and from mikes last post i think i have negative camber.. any way of changing this??
Old Jul 9, 2008 | 01:18 PM
R5FORD's Avatar
R5FORD
nah there staying as the mos suit it
Old Jul 9, 2008 | 01:21 PM
Dingy's Avatar
Dingy
I trust the man i take my car to.....
i wouldn't trust ahmed to setup a car when he gave me the totally wrong advice about my own....and as mike listens to him i rest my case
Old Jul 9, 2008 | 01:25 PM
Dingy's Avatar
Dingy
Mike - surely you setup the car with the car and not some figures you made up....
The person that sets my car up knows how to make the car handle and says you can't go from figures on the net with out actually having the car cause they are all different......so it might have different effects depending on the straightness off the car - so as most fords are bent from the factory using these settings would proabably make it all wrong LOL...
I believe an expert over ahmed/mike
Old Jul 9, 2008 | 01:32 PM
costina's Avatar
costina
Live long and prosper!!
Its too low!! a Saff will handle likea boat a give less traction when lowered a lot.
Thats why i have std height springs
You could just put 2 0.5mm washers between the hub and arm at the top to help this / \ problem or to gain this / \ viewed looking down on car u will need Mike's shims
Paul
Old Jul 9, 2008 | 01:33 PM
CossieRich's Avatar
CossieRich
oh dear
Old Jul 9, 2008 | 01:35 PM
R5FORD's Avatar
R5FORD
oh dear
Old Jul 9, 2008 | 01:36 PM
R5FORD's Avatar
R5FORD
Paul
i have std height sprinhs here just dont like the car with them on.
Old Jul 9, 2008 | 02:06 PM
Mike Rainbird
Caraholic
Steve,
To some extent that is true, as even wheel size effects what geometry settings you should chose. However, you have to have a basic starting point, so you make the assumption that the car is straight not bent .
The figures may be made up, but they are made up by Boram RS technicians . They obviously work though, as is being advocated by other people that have set their cars up on this advice. You can diss it all you like, but I know how to make a Cossie go round corners. Obviously you cannot apply the same methods to different set-ups and I would never profess to know how to make your Escort handle .
Old Jul 9, 2008 | 02:12 PM
CossieRich's Avatar
CossieRich
Not even a word of thanks Mike for actually sticking up for you for once Harvey not allow it or something
