Which pistons & rods???
I have a dilema,
im having a zvh bottom end built for me soon, but there are 2 companies offering me different options.
One is a standard block with wossner forged pistons and standard rods & crank.
The other is a new but standard block, new standard crank, eagle steel rods and je forged pistons.
The second engine is £200 more thank the first engine. The car will be running around 14-18 psi with the goal of around 225bhp with loads of torque.
I have never used any of these makes so any advice would be great
Passionate about fords
for £200 more you get steel rods etc, go for that, ive got a bottom end with je pistons and eagle rods, i havent used it yet but the previous owner ( jamesS2RS ) got good power from it and turboboss ( sean ) on here uses the same.
dave.
dave.
very true, but a zvh will hardly be working to produce that power, plus the torque lower down the rev range will be much greater. Ive had 3 rs turbo's all around 200 bhp and the power is usually near top end, so im after a fast engine with great reliability and low down power (if there is such a thing.lol)
im running 2.1 zvh using c2o xe forged pistons and standard rods @ 16 psi with 267 bhp. having the low down power is usless even on a hot summers day i cant get grip in first and second and struggles in third at 3000 rpm. im going for full zetec next year for more equal power throuout the rev range.
the engine ive got made 300bhp and 360lb/ft mate at 26 psi peak and holding 24 psi, i think turboboss ( sean ) made even more than that, pm him buddy and he will give you some good info, let me know what he says !!!!!. but like i said, for only an extra £200, if you are wanting a zvh then id def pay it seeing as you get steel rods etc.
dave.
dave.
As long as the Wossner pistons are the low-compression version for the zetec, then that's the better option really for what you want.. cheeeep!
Standard rods are good to, well, I don't know anyone who has broken one on a well-tuned car (up to 300bhp)..
My gearbox is only mildly uprated with uprated bearings, but still standard cogs and v-lsd
imbarrassed any lush motors?
standard gearbox waiting for it to break tho lol, first and second are usless 3rd is awsome once it grips and 4th and 5th aint bad either. i cant realy explain the gears much but over a half mile length from standing start it pulls up to 125mph then i need a 6th. what management you gonna be running?
the cheaper gotech ecu, think its called mfi pro or maybe the mini, the only difference is that its slightly newer software and there are more features such as lauch control, boost controller, nti lag etc. These are features I just wouldnt useso pointless having it. As for lush cars, things like scoobies etc, my bro has a sti prodrive 305 bhp and my sis has a standard evo8 260bhp, would be nice to be able to keep up with them in a straight line
lol, did you weld the head on your zvh? one of the guys who maybe building my block has recommended having the head welded so that a zetec metal gasket can be used instead of a felpro gasket
1100 - wossner pistons
1300 - je pistons/eagle steel rods
what you reckon?
they both sound like top guys so its decision time
one thing is the compression ration, the wossner pistons will be 8:0:1
is this any good? dont know what compression the je will be
what you reckon?
The Wossners will be roughly 8:1 on a 16v engine, it'd be considerably lower with a CVH head due to the enlarged combustion chamber. Same applies to the JE's. You will never know what the CR will be until you actually measure it.
well im not into guess work, is there not z way of working the ratio out with out dummy building i.e. burton power can machine pistons to suite sny rstio sd long as they know the cc of the head. Only reason is that I already have a stage 3 race head and the block is being built miles away from me so it would make sence to have any machining done when the block was being built instead of me taking it apart again. Plus I havnt got a clue how to work out c/ratios or more to the point which ones are best and what are to low - high.lol
Thats not what I wanted to hear! burton told me that it would be fine, well I would rather take your word for it as im sick of performance suppliers spinning me a long one just to get a sale, do you know how I can work this out if I so a dummy build? I want to get it right first time. I think I will put another post up in a bit about what sort of comp ration to go for.
Cheers mate
Cheers mate
i think its each man to his own, some say 250 some say 300, its all up to you, but for the extrac piece of mind I would recommend going steel. Ive decided to go for forged pistons and steel h section rods, the zvh block is costing me 1300 to be built with new block, new (standard) crank, pumps and heavy dudty bearings. the engine is rated at over 450bhp so should be pretty reliable
(but it is a ford.lol)
orion=mini saff
TBH i was gonna stick with stock bottom end to start with,least if it goes pop its a easy replacement job,rather not kill a set of steel rods and pistons,lol
if it was me i would not use steel rods unless i was aiming for 300 but if that may be an option in the long run then it would be worth doing it now. if not i would use c20 let pistons cheep(second hand) and forged. need slight machining to accept the rods.
I ran standard rods on full zetec with a t34 hybrid running 20psi polished ported head grs intercooler etc and they never let go but were pushed to the limits when i stripped the engine to replace for steel and forged pistons you could see the little end of the rod discoloured through heat and thats where they will go, if your aiming for 300 or above i would recommend steel rods, as for crank the standard crank is very strong but will only take up to 400bhp.
orion=mini saff
they worth using with the hassle of having them modded to fit the zetec rod??
Chris did I speak to you on the phone?
Hi sorry to butt in again, i built numerous engines and ran the vauxhall pistons pal they sit further down on the gudgen pin dropping the compression by sitting further down the cylinder but people often overlook the under piston oil cooling spray bars which the zetec needs. I have found that when given alot of boost the pistons movement knocks these bars off when you build the engine the clearence between the piston and the cooling bar is minimal, when i have stripped other customers engines down who have come to me saying they have melted number 3 due to fuel and air being wrong its turned out to be no spray bars which will cause the piston to get too hot not the mixture. sorry if i am going on and interfering
Hi Raj that compressin ratio sounds ok but you will be safer getting a dummy build done the reason being with the xe conversions the piston is sat down the cylinder so there is no chance of clipping the valves where as the forged piston needs to be measured acurate because the piston will sit flush with the block and the compression will be lowered in the bowl depending on the piston. I have had the cambelt slip on a full zetec due to silly powder coated verniers and it never touched a valve because of how the piston sits in the cylinder .
this may sound daft, dummy build = put head on with the head bolts fully tightened? then turn the crank a few times???
Sorry if this makes me "sound a bit fik"
