blue smoke on cossie
Old Jul 7, 2008 | 03:14 PM
xr4x4rs's Avatar
xr4x4rs
Default blue smoke on cossie
ok need some things to check
as the car has started to smoke, but its only when you give it some in 1st or 2nd or when your crusing down the road and when yu pull up theres a big cloud of blue smoke that comes over the car
i carnt seem to find whats causig it, ive took the turbo off to have a look and looked in the ex ports and its all dry no wet atches anywhere to say its rings or something
turbo is fine or it would do it constantly id imagine
so im a bit stuck now
could a blocked breather cause this?
it started 3 days after i fitted a new turbo
Old Jul 7, 2008 | 03:18 PM
Munch's Avatar
Munch
Mr. Sparkle!
blue smoke is normally Turbo related isnt it but i dunno with your car, hasnt your engine not long been rebuilt?
Old Jul 7, 2008 | 03:24 PM
Staffi's Avatar
Staffi
Lee, my thoughts too, but wouldn't a turbo issue be smokey in all gears etc??
Old Jul 7, 2008 | 03:41 PM
xr4x4rs's Avatar
xr4x4rs
surely the turbo would do it constantly on tickover aswell
well all exhaust ports are dry, but just stuck me head in the bay and had a quick look inside the ports, and on port 1 one of the guides has a bit of oil round it
so it could be a dodgy stem seal or the valve guide is leaking which i can live with as i dont mind taking the head off for that
even though ive just had them all done
im just going to double check first, but it does smoke quite a bit when i pull up and give it some, im unsure in other gears as its hard to see, and its mainly at night when a car is behind me i see the full extent of the smoke, but 3 rd gear theres no cars behind
Old Jul 7, 2008 | 03:45 PM
Staffi's Avatar
Staffi
Off topic slighlty ..when's the next meet fella??
Old Jul 7, 2008 | 04:15 PM
Jay,'s Avatar
Jay,
Sponsor
havnt you already been ripped off over the turbo already and i agree it does sound like its the turbo rich
Old Jul 7, 2008 | 04:24 PM
xr4x4rs's Avatar
xr4x4rs
if its turbo im just gona send it into turbo technics
but yes im on my 3rd turbo in 3000 miles
im just putting it all back together now, gona start it up as my breather is breathing heavy aswell, so gona disconnect the pipes to see where its from, if its cam cover im gona block it up, and im gona remove the kidney box aswell
will give it an oil change this week aswell, even though i havnt done 400 miles yet, but its burning it within a week
the car is really annoying me lol, and if i carnt sort it its going and im going to get something reliable
staffi, next meet would be i think 4 weeks from the last one so 31st of this month would be the next one, where i havnt a clue will need to sort it out nearer the time
Old Jul 8, 2008 | 01:02 PM
xr4x4rs's Avatar
xr4x4rs
well, i got it all back together and it still does it, i carnt find where or why its smoking
breather pipe is breathing from the one coming from the flametrap, so what does this mean?
really annoying, why carnt things just break as i dont mid that, i just hate blue smoke as i could be chasing for ages
Old Jul 8, 2008 | 01:07 PM
Ryan's Avatar
Ryan
if its turbo again then its 1 of 3 things:
Shit turbo builders
Bad oil supply Pipe/Pump Worn
Oil Contamination/Overfueling causing oil to run thin and wear bearings and turbo bearings.
Old Jul 8, 2008 | 01:11 PM
costina's Avatar
costina
Live long and prosper!!
Heavy breathing from flame trap could be rings or blocked pipe
when u changed turbo did you clean out the intercooler and pipes??
only one drop of oil into the intake will cause a big puff out back when on boost!!
Check the thottle elbow if a 2wd one for oil in there,if there is u will need to strip all the intake and clean that aswell
Paul
Old Jul 8, 2008 | 01:13 PM
costina's Avatar
costina
Also to add when your turbo first went was it leaking oil from the compressor side front housing??
Also check theres no oil coming from this area into the cooler
Paul
Old Jul 8, 2008 | 01:16 PM
xr4x4rs's Avatar
xr4x4rs
the last turbo never had any oil problems, it seized
there wa sno oil traces in my pipes or intercooler, but i have a slight bit on the lip of the compressor hosuing when i take the air filter off thats it
pump is fine and i get 75psi of pressure cold and flat out
unsure on fuelling but the gauage i have says it isnt running rich, but its just rite
im on 2wd oil feed set up with a new pipe and new bailey filter, recommened by turbo supplier
i will take the inlet off and have a look this week see if theres anything in there
but its when i come to a stop and a cloud of blue smoke comes out which is the annoying part, as it comes across the front of teh car and people have windows down in there car they get the full smell of it
Old Jul 8, 2008 | 01:17 PM
xr4x4rs's Avatar
xr4x4rs
Paul
carnt remember to be honest, nut i know ive never had any oil in the pipes
badnews's Avatar
badnews
a compresion and cylinder leak test will give you an idea of whats going on but sounds like a turbo issue if you'v just replaced it, i hope it's not bad mate best of luck
Old Jul 8, 2008 | 01:20 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Shit turbo builders
That sounds like a plan.....
Old Jul 8, 2008 | 01:21 PM
costina's Avatar
costina
It theres and oil in the inlet its deffo turbo related there should be no oil from the compressor to intercooler maybe only a skicky residue no dips at all
Paul
Old Jul 8, 2008 | 02:04 PM
xr4x4rs's Avatar
xr4x4rs
ok, ill take a look, im getting new gaskets thursday so i can do it
then next week ill get it booked in for a leak down test
S3an
Sep 26, 2015 11:39 PM
Brickhouse
Sep 21, 2015 04:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
S3an
13
Sep 13, 2015 10:01 AM
Mickeystewart
Sep 9, 2015 04:04 PM
