how can i tell if turbo is fcuked
Old Jul 6, 2008 | 08:35 PM
stembo21's Avatar
stembo21
Default how can i tell if turbo is fcuked
i went out today for a bit on my way home i give my car a bit of boot and i poped to my mates when i stoped it was smokeing (blue) it has never done it before so i drove it home and it got worse so i have the turbo off i also took the head off to see how the head gasket is as i want to put a good one on anyway the piston and bores are real good.
as for the turbo when i took it off i blew down the oil way and i bunged up the return and i can here it leeking am thinking its not supposed to do that can anyone tell me how to check the turbo?
here are some pic you cac just see the oil in the turbo
Old Jul 6, 2008 | 09:19 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
fooked turbo:
in and out play, side - side play, it may have minimal side to side play, thats ok but lots ='s fooked
also if their is some oil on the inlet side or oil in boost hoses you've generally got a problem
Dave, non expert.
Old Jul 6, 2008 | 09:29 PM
stembo21's Avatar
stembo21
fooked turbo:
Dave, non expert.
the only other thing i can fink of is the stem seals but am sure its the turbo i dint think they can just go like that
Old Jul 6, 2008 | 09:45 PM
rst in breaking's Avatar
rst in breaking
would have tried a compression test myself before the head was off as regrdless how good the bores look could have a cracked ring or piston or something thich may have shown up in a test
Old Jul 6, 2008 | 09:50 PM
stembo21's Avatar
stembo21
i might just put the head on this week and do that but do you know what psi it should show
Old Jul 6, 2008 | 09:54 PM
vroooom ptssssh
It Wasnt Me!
Also use a standard ford Payen gasket
Old Jul 6, 2008 | 09:56 PM
rst in breaking
i think the norm is around 150psi
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
