series 1 cossie turbo!
Old Jul 6, 2008 | 08:14 PM
JoeRS22's Avatar
JoeRS22
Default series 1 cossie turbo!
hey people wondering if you can give me some advice on behalf of me mate, its a series 1 escort with cossie management he has taken the engine out which was running fine to get the car resprayed, got it back and the only things done was a new timing belt and group a fuel pump, the timing we sure is right but do you need to turn the fuel pressure down due to the pump or any other ideas??? it does sort of start but hardly runs and loads of smoke (lots of fuel) ???? thanks
Old Jul 7, 2008 | 09:49 PM
JoeRS22's Avatar
JoeRS22
Old Jul 8, 2008 | 06:46 PM
wardchris's Avatar
wardchris
Hi pal what fuel pressure regulator do you have on it the cosworth one??
Old Jul 8, 2008 | 08:14 PM
JoeRS22's Avatar
JoeRS22
hi wardchris yes it is, ive tried setting it down tnt no difference im wondering if something else is wrong, also checked timing again and trigger ring on cam pulley for spark, it just aint firing correctly any ideas????
Old Jul 8, 2008 | 08:26 PM
wardchris's Avatar
wardchris
Have you still got the other pump ???
Old Jul 8, 2008 | 08:27 PM
JoeRS22's Avatar
JoeRS22
i think my mate has whys that???
Old Jul 8, 2008 | 08:33 PM
wardchris's Avatar
wardchris
Just thought of refitting the original if its not a big job and see how it runs ??? is it a full cosworth setup ie what injectors etc ??
Old Jul 8, 2008 | 08:34 PM
wardchris's Avatar
wardchris
What pump was on and whats been fitted pal ?
Old Jul 8, 2008 | 08:36 PM
wardchris's Avatar
wardchris
Was it a standard cosworth pump to an uprated one ? or rs turbo to cosworth ?
Old Jul 8, 2008 | 08:38 PM
bad boy rs's Avatar
bad boy rs
Bring it down my garage tomorrow i will set it up for you
Old Jul 8, 2008 | 08:43 PM
JoeRS22's Avatar
JoeRS22
it a new standard cossie pump from auto specialists and it is running dark greens?
Old Jul 8, 2008 | 08:45 PM
JoeRS22's Avatar
JoeRS22
hey paul how ya doing long time no hear
Old Jul 8, 2008 | 08:52 PM
wardchris's Avatar
wardchris
I shouldnt think you should have problems with that then your best bet is to have it set up ie fuel pressure etc. It needs setting right with a proper pressure gauge pal.
Old Jul 8, 2008 | 08:57 PM
JoeRS22's Avatar
JoeRS22
Engine advantages it is then i think cause bore washing is very likely at the mo...
Old Jul 8, 2008 | 09:02 PM
wardchris's Avatar
wardchris
Yes pal not good any way you could trailer it ??
Old Jul 8, 2008 | 09:06 PM
JoeRS22's Avatar
JoeRS22
i think me mate has got a flatbed truck sorted cheers dude.
Old Jul 8, 2008 | 09:08 PM
JoeRS22's Avatar
JoeRS22
my mate has got a flatbed truck sorted dude.
Old Jul 8, 2008 | 10:18 PM
s1cab's Avatar
s1cab
help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :f ume:
s1cab's Avatar
s1cab
its me !!!
Old Jul 8, 2008 | 10:19 PM
s1cab's Avatar
s1cab
hello joe i am here to save the day! hurry up and fix ur cossie!!
Billy_RS
16
Oct 11, 2025 09:41 PM
Oct 9, 2015 07:38 PM
carlo
24
Oct 5, 2015 08:20 PM
Matt Baxter
Sep 16, 2015 08:30 PM
adriansaleem
Aug 1, 2015 09:28 PM
