How do rev counters work?
Old Jul 6, 2008 | 05:03 PM
pee vee's Avatar
pee vee
Default How do rev counters work?
as title really, what 'feeds' them to make them move?
do they have a switched live to them and just get a -ve from the coil, every time it fires?
using an old style coil set up as an example
thanks.
P
Old Jul 6, 2008 | 05:23 PM
Nash_mr2's Avatar
Nash_mr2
cable running from the gearbox,
ignore me - i thought u said Speedo
the rev counter runs off a wire which is receiving an electronic current from the coil
Old Jul 6, 2008 | 05:24 PM
pee vee's Avatar
pee vee
thats the speedo mate.
Old Jul 6, 2008 | 05:43 PM
blacky.'s Avatar
blacky.
its black magic you turn the key & they work unless you run coil packs then the read double or not at all
Old Jul 6, 2008 | 05:49 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
The ford ones rely on the collapse of the coil generating back EMF to drive them I believe, so arent a simple example.
most work how you described though
Old Jul 6, 2008 | 05:51 PM
pee vee's Avatar
pee vee
I am now running coil pack, and different ECU.. and have a tacho driver from the ecu to the rev counter...
just basically wondering what i should be seeing at the wire that feeds the rev counter!?
ive got about 6v at idle... but i was kinda expecting it to be a pulsed -ve LOL doh.
Old Jul 6, 2008 | 06:24 PM
focusv8's Avatar
focusv8
It will be a pulsed output, but you won't see the pulses on an LCD volt (multi) meter they don't react fast enough.
Old Jul 6, 2008 | 08:01 PM
pee vee's Avatar
pee vee
something is definitly wrong then lol
hmmm
Old Jul 7, 2008 | 06:21 AM
Depending on what type of signal the tacho is looking for you may or may not need a tacho driver, the std sierra one will with coilpack, the emerald ecu for example can be CALIBRATED as well to the tacho to make it accurate at all times, as ecu output can be massaged.
Dahl88
Aug 22, 2015 08:16 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
cozzy jeff
Aug 14, 2015 05:46 PM
stevierob
Aug 11, 2015 09:08 PM
