quick question guys (ref cossie suspension)
Old Jul 6, 2008 | 04:29 PM
bailey1's Avatar
bailey1
Default quick question guys (ref cossie suspension)
is the front suspension on a 3 door exactly the same as that on the 2wd sapph's ??? ie not very similar which is why people do switch em about is there any differences in measurements/tolarances etc etc ??? im only really on about the mcpherson strut and coil spring not coilovers or anything. cheers in advance people
Old Jul 6, 2008 | 05:00 PM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
All the same bar the hubs iirc.
Old Jul 6, 2008 | 07:50 PM
bailey1's Avatar
bailey1
cheers for that
Old Jul 7, 2008 | 06:23 AM
Geometry TOTALLY different between the two, some caused by totally different front hubs/roll bar.
Suspension rates totally different front and rear for 3door/2wd sapph.
The PHYSICAL fitting is the same for struts/springs though.
Old Jul 7, 2008 | 07:31 AM
Mike1's Avatar
Mike1
I've posted this before but it might interest you
These are some of the changes from 3-door to Sapphire 2wd made by Ford.
Obviously the 4-dr shell was stiffer which has to be taken into account.
Spring rates went up from 106 to 118lb/in at the front and 263 to 286 lb/in at the back.
Damper rates were made softer in bump and stiffer in rebound.
ARB was increased to 16mm on back
Castor increased by over one degree
Camber made fractionally more negative
Kingpin inclination made slightly greater.
Front knuckles re-designed to lower the front roll centre from 144mm to 70mm
Old Jul 7, 2008 | 11:03 AM
Having rate tested a pair of std cossie(sapph2wd) front springs the rate was 190lb".
Anutternutter
24
Aug 31, 2015 01:24 PM
c20tbo
Aug 17, 2015 10:19 PM
Gadget
Ford Escort RS Cosworth
Aug 13, 2015 06:43 AM
Ben26
Aug 11, 2015 04:19 PM
liam-rst
Aug 10, 2015 08:46 AM
