what do i need to wire electrc to my shed?
ive got a large shed next to my house but want to wire a 2xplug socket to the shed.
to be safe am i best to just run the sockets of a 3pin plug into the house im going to run the cable underground covered in plastic sleeving.
What wire do i use and any other bits will i need?
get a sparky in mate
i wouldnt use plastic sleeving i would use an armoured cable! i remember when digging a pond at our old house we found the electric cable to the shed and just thought it was a tree root so tried to break thru it with the spade, good job it wasnt just covered in plastic sleeving lol
you can get a conduit for the cable ,armoured is exspensive if you need a lot.
Wire a fused spare from a socket and then inti the shed ,small fuse box about £70 quid,not that difficult.
Sure there will be a sparks allong soon
or if you have a spare space in your fuse box ,buy a circiut breaker and wire it directly to that.
many different ways so best to get a proper spark along and not just rely on the opinions of internet experts.
We have a proper consumer unit, fed by armoured cable to the main consumer unit for the house. There is then a proper lighting and ring-main circuit in the shed.
Only thing I'm thinking about changing are the 2 bulkhead lights for fluorescents.
been told to deffo use flurescents
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
