any ideas on this
Old Jul 6, 2008 | 11:28 AM
saph4be's Avatar
saph4be
Default any ideas on this
after rebuilding the engine on the cossie it all seems fine till it starts to boost and then it pops and backfires and cuts out and will re start again no problems drives fine off boost just getting some ideas in so i can get a look at it if it ever stops raining
Old Jul 6, 2008 | 11:30 AM
jacko's Avatar
jacko
try the plugs mate
it can blow out the spark on boost if it dont have the right plug or gap
Old Jul 6, 2008 | 11:38 AM
Si B's Avatar
Si B
2Evos & 1 Escort Van :-)
Have you got all plugs plugged in correctly?
Timed up correctly?
I once had similar problem, and IIRC I had my CPS and dizzy plug or maybe MAP sensor or similar plugged in back to front - can't remember exactly what I had plugged where, but car drove mint off boost, then popped and banged on boost.
Swap plugs so they are right and it worked sweet
Old Jul 6, 2008 | 11:41 AM
saph4be's Avatar
saph4be
[QUOTE=SiB;3407833]Have you got all plugs plugged in correctly?
Timed up correctly?
Swap plugs so they are right and it worked sweet [/QUOTE
my dizzy plug wires were damaged and i re solderded them tohether could they be the wrong way round
Old Jul 6, 2008 | 11:47 AM
Si B's Avatar
Si B
[quote=saph4be;3407844]
Timed up correctly?
Could be, but you would need someone clever with electric stuff like Stu, Dingy or Ryan to help you diagnose that.
I guess there is a way to test it, but I wouldn't know as I'm not as clever as the above names!
Si
Old Jul 6, 2008 | 11:51 AM
jameswrx's Avatar
jameswrx
could also be something as simple as a bad main earth too
Old Jul 6, 2008 | 11:52 AM
Cossie Helen's Avatar
Cossie Helen
I have problems before with my dizzy and phase sensor, replaced both and misfire was sorted.
Misfire is back again, but this time on mine it is the multiplugs.
Old Jul 6, 2008 | 04:41 PM
cossiegreg1's Avatar
cossiegreg1
timing or map sensor
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Fezman1
Oct 2, 2015 01:22 PM
Orion_Gav
Sep 29, 2015 04:50 PM
rogerxr3i
Sep 13, 2015 06:56 PM
