radiator pressure in capri 2.8i
hi guys. Took the capri to work today (about 13 miles) after fitting thermostat and doing few other bits and bobs over the last couple of days.
Car got me there sweet as a nut. Left work, drove about 1mile just about to jump on m4 and i saw water spraying on window. I thought it was starting to rain, but i slowed down slightly and saw water spraying from bonnet. Pulled over and the rad had blown a big hole. The water was luke warm so it deffo not over heated.
Originally when i got the car it didn't have a thermo so should i just take it out again? I'm under the impression that the viscous fan has nothing to do with it anyway. Runs off a different water temp sensor or something.
The problem is (according to AA) that there is alot of pressure in the rad. I'm assuming its because of the thermo.
Any advice please?
Any advice please?
having a thermostat is NOT your problem, every bloody car has one... lol
never listen to anything an AA man tells you, if they knew what theywere talking about they wouldnt be earning minimum wage working for the AA would they
sounds like your 20year old rad sprung a leak, nothing mysterious about that
Well the Rad was very old so I was hoping that was the problem. It wasn't exactly pissing out at high pressure and like i say it wasn't even hot.
The Rad prob was blocked as the water was brown when I got the car. I have since flushed it but i'm guessing it could still have been blocked. Do you think it worth removing the stat anyway?
I really dont think its headgasket to be honest.
For some reason this post has duplicated itself three times. One post is good enough
Thanks for the help
Thanks for the help
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
