Cossie T3 on a S2 Yes/No?
Shall i put i cossie T3 on my S2 1.8zvh i know ill need a new down pipe but is there any reasons why not to? Like Pro`s & Con`s?
Well they are different but i will have to get a custom downpipe made (i assume they are abt £80?)
RST is 45 trim compressor A/R .42, 0.36 5 stud elbowed turbine housing
2wd cos is 55 trim compressor A/R .42, 0.48 3 stud non elbowed turbine housing
Are they the same? Will having a bigger exhaust housing be better in any way? (if i stick with the cossie one?)
just take the cossie ex housing off and fit an rs turbo, may need to undo the compressor and twist the core and compressor housing to match up with your pipes etc, but that sit lol
Bodybuilding
From: Cannot be identified by the information given.
using the cossie t3 compressor would turn it into a stage 2 rs turbo hybrid
if you use the cossie .48 exhaust housing also it would be a stage 3 hybrid if not better
Russ Payne
Sep 25, 2015 08:29 PM
