hey guys, ive broken off side front driveshaft. does anyone know where i can get new ones from or reconditioned ones, ive tryed the owners club and they aint got none. any help would be greatfull.
Ford were doing a complete shaft & joints reconed for Ł225 ish on an exchange basis, but this was some time a go. You can get just the joints if thats all thats broken.
i destroyed the tripod, and the end of the shaft looks sheared!
Sounds daft, but this happen to me - turned out my standard passengers engine mount was dead (in two pieces) and one hard launch later, the engine pulled to tha passengers side and popped the driveshaft out.
I fitted some Vibra Technics engine mounts and I have never had a problem since.
May be an idea to check you engine mounts at the same time.....
