**updated**no juice 2 injectors
Old Jun 30, 2008 | 06:22 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default **updated**no juice 2 injectors
put new engine in wnt start, juice wont go from meterin unit 2 injectors,
changed the followin,,
both ecu, black n silver
fuel pump/relay
meterin unit x3
plugs+leads
all sensors/clips on right
starts for 1 secound on 2-3 cylinders then cuts out, must b the unmeterd cold start supply
had enuff now bin off the road 11 months, im going to efi it an hope it starts then, i hav all the parts ready any more ideas b4 i start doin it cheeRs
Old Jun 30, 2008 | 06:24 PM
haz87's Avatar
haz87
Have you swapped the injectors for known good ones?
Old Jun 30, 2008 | 06:43 PM
TuRbO-CaB-LaD
nope i havnt, i thought if the juice wasnt leaving the meterin unit it wasnt the injectors, could i be wrong?
Old Jun 30, 2008 | 07:03 PM
g1234's Avatar
g1234
crack all banjos on meterin head see if fuel is at all the banjos good old mfi units are s##ty and very temprimental
Old Jun 30, 2008 | 07:08 PM
TuRbO-CaB-LaD
iv took the 4 injector lines off the metering unit, got sum1 to turn it over, you can see the fuel sitting in it wer i took the 4 bolts out, wen i press the flap down 5mm nothin happens, wen i push it right down it comes out but not wiv any pressurean the injectors are like making a buzzing sound?
Old Jun 30, 2008 | 07:11 PM
g1234's Avatar
g1234
sounds metering head problem mate soon as you touch flap it should come out or maybe your pump is on way out not getting enough pressure up tyr undoing banjos on filter to meterin head if there is loads of pressure buildup there its most likely meterin head
Old Jun 30, 2008 | 07:23 PM
TuRbO-CaB-LaD
yh i have done mate, i hav loads of pressure from the filter 2 meterin unit, would tht mean my meterin unit is faulty?
Old Jun 30, 2008 | 08:03 PM
haz87's Avatar
haz87
Have you tried the two man method. One person turns the engine over while the other applies a small amount of pressure to the flap. This should force the fuel up to the injectors and fire (hopefully)
Old Jun 30, 2008 | 09:00 PM
TuRbO-CaB-LaD
yh iv tried tht method and bridging the pump, still no joy, wen i push flap no petrol comes out
Old Jun 30, 2008 | 10:58 PM
g1234's Avatar
g1234
definatly meterin head problem mate there not worth pissin about with look for a new one
Old Jul 1, 2008 | 08:11 AM
picky775's Avatar
picky775
better still bin all mfi stuff and go efi,had the same problem with mine and never figured it out done the same with another metering head aswell so binned it all and went efi instead,much better
Old Jul 1, 2008 | 04:14 PM
juffer's Avatar
juffer
is the pump working corectly and corect fuel supply? remove the fuel return pipe that comes off the pressure regulator at the back of the metering unit place a container to catch the fuel then bridge the fuel pump relay for 20 seconds and you should have roughtly 0.75 of a liter of fuel come out.
Old Jul 1, 2008 | 05:13 PM
TuRbO-CaB-LaD
iv tried bridging the pump, i will try takin the return off 2morrow cheers
Old Jul 9, 2008 | 01:00 AM
TuRbO-CaB-LaD
took it sevs in willenhall, got it started after a hour, buzzzzzzzzzzzzzzing!! bk on road an running sweet!!, 2 valves wernt sealing properly, missed 2 washers wen i swapped the head an valves ova!! soon as sevs put 2 washers on, fired straight up! didnt charge me much either!!
adress n website below!
www.sevs.co.uk
Tel: 07966522160
Unit 10 Sevs
Reflex Business Park
Willenhall
WV13 1AH
Old Jul 9, 2008 | 01:11 PM
haz87's Avatar
haz87
Top stuff
Old Jul 9, 2008 | 02:00 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
glad its sorted
Old Jul 10, 2008 | 08:52 AM
paul66 turbo's Avatar
paul66 turbo
Default r
what washers where missing mate
Old Jul 10, 2008 | 02:30 PM
TuRbO-CaB-LaD
the head on the hydraulics, 2 threads out the 8 had longer thread, so it was jus out, used 2 washers to equal it off so the valves sealed properly
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
