shocked
Old Jun 29, 2008 | 06:52 PM
davie_rst's Avatar
davie_rst
Default shocked
was bummin onto my boss about my rs the other day just to get beat by his mini cooper s what mods can a do to get it beatin the hairdressers car my car is runnin more or less standard cheers davie
Old Jun 29, 2008 | 06:53 PM
haz87's Avatar
haz87
In english?
Old Jun 29, 2008 | 06:59 PM
davie_rst's Avatar
davie_rst
that is english bud
Old Jun 29, 2008 | 07:45 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Standard RST's are 'ok' but never beat a cooper S with one!
you need firstly:
Mongoose/Magnex exhaust
chip (to remove boost limit)
front mount IC (so you can raise the boost safely with the chip and not have sky high charge temps, the std IC is 'ok' for 13psi any more and it struggles)
then a high lift cam
keep the std airbox and cut the front off where the circular hole is on the top half of the lid!
with all that you'd be looking at around 180-190bhp on 13-14psi setup correctly on a healthy engine.
After that your into hybrid/bigger turbos and lower compression pistons but if the engine is coming apart i'd go for a ZVH or Zetec Turbo!
Cooper S's (the old ones) have 163bhp, 0-60 in 7.4 and a 135 top end
nothing rapid, get it chipped, exhaust, cam and a bigger IC and you'll have him
Old Jun 29, 2008 | 07:50 PM
nickscunny's Avatar
nickscunny
Translation i think:
I was winding my boss up about my RS the other day and i ended up getting beat by his Mini Cooper S. Question is what mods can I do to get it to be more powerfull than the hairdressers car. My car is running more or less standard.
Thank's Davie.....
Thats in English.....
Old Jun 29, 2008 | 08:12 PM
davie_rst's Avatar
davie_rst
cheers for sorting out my english there yes ill have to sort out the engine because we cant have the little mini destroying the rs name lol maybe its just the way i drive cheers guys
Old Jun 29, 2008 | 10:37 PM
T28 RST's Avatar
T28 RST
Ok then
was bummin my boss
cheers davie
Rod-Tarry
75
Oct 13, 2015 04:44 PM
Fiddy
21
Sep 29, 2015 06:10 PM
SMILER258
Sep 28, 2015 09:04 AM
L1AM_RS
Sep 23, 2015 03:27 PM
