Petrol Sat In Bottom Of Metering Unit
Old Jun 29, 2008 | 12:55 PM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Default Petrol Sat In Bottom Of Metering Unit
Car is possibly overfuelling there is alot of petrol sat in pipe that comes from metering unit to the turbo, n e ideas peeps? tried to upload pics but culdnt figure out how 2
Old Jun 29, 2008 | 01:14 PM
Jim Galbally's Avatar
Jim Galbally
sounds like it's leaking. for enough fuel to get back form the inlet track, thru the turbo and then into the metering head you'd have SERIOUS problems.
Old Jun 29, 2008 | 01:15 PM
Steven_RW's Avatar
Steven_RW
I thought we covered this?
Regardless of whether it is over fueling or not - extra fuel should end up in the BORES not in the metering head.
If it is appearing below the flap on the metering head, maybe the metering head is leaking.
RW
Steven_RW's Avatar
Steven_RW
Yeah - the only other option is it is traveling back via the breather pipe that feeds into the lower half of the metering unit. However you would expect oil (naturally) and not fuel.
RW
Old Jun 29, 2008 | 01:20 PM
Adam.'s Avatar
Adam.
checked both plugs on back of inlet they r sorted, so it looks like the metering head is fooked?
Old Jun 29, 2008 | 01:29 PM
Jim Galbally
thats what we just said yes, something is leaking fuel
Old Jun 29, 2008 | 01:31 PM
Adam.'s Avatar
Adam.
n e one got a decent metering unit?
Old Jun 29, 2008 | 01:37 PM
babscossie's Avatar
babscossie
metering unit is DEFINATLY leaking mate. seen loads of the rst's do this.
Old Jun 29, 2008 | 02:23 PM
Steven_RW's Avatar
Steven_RW
Unlucky chappy - the plug would have been a nice easy one.
Need to find someone scrapping a running rst.
After that - THEN u will need it setup properly as the chances are the previous RST wont have been running the correct fuel settings for ur car.
Cheers and GL
RW
Old Jun 29, 2008 | 03:24 PM
Adam.'s Avatar
Adam.
Thanx pal
timsrs
Nov 13, 2018 11:48 AM
155lee
Oct 24, 2015 11:11 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Bransby
Sep 21, 2015 05:29 PM
rs_jim
Sep 19, 2015 08:41 PM
