N/A High Comp Zetec......
Old Jun 29, 2008 | 08:59 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Default N/A High Comp Zetec......
Anyone built a High Comp N/A Zetec?? What pistons etc did you use?
Old Jun 29, 2008 | 09:07 AM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
i havent built one, but an planning on it... i'm going to use the je 9:1 compression pistons with an st170 head (skimmed quite a bit), should work out at 11:1 ish... but it depends on what you call high comp? i worked out that the domed JE's made it up to the high 12's or 13's...
Old Jun 29, 2008 | 09:16 AM
TimC's Avatar
TimC
Think your best looking for a chap with the user name i think FreakPower. He has that mad 8 injector throttle bodied orion.
Old Jun 29, 2008 | 09:23 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
I built one once at 13:1 using modified Eagle rods and Accralite pistons using a normal zetec head.
boeb
Jan 9, 2020 05:11 AM
