Securing a wireless router...
Old Jun 29, 2008 | 02:21 AM
cossie04's Avatar
cossie04
Default Securing a wireless router...
How do i do it? I`ve bought a wireless router which is installed but at the moment it is a `Unsecure Network`. Anyone know how to make it `Security Enabled` please?
Cheers, Ed.
Old Jun 29, 2008 | 06:01 AM
On my one from plusnet I had to go into the plusnet software and do it, if I can do it anybody can, on security settings.
Old Jun 29, 2008 | 07:28 AM
Madbradz's Avatar
Madbradz
Find your routers address. Usually http://192.168.0.1 or http://192.168.1.1 Type that in internet explorer, Should ask for a username and password usually Admin / Admin
Once your in find wireles security settings an set a wep key, Make sure you write it down, then that should be it... but you will need to enter the wep key into the computers that are connecting to it.
Hope that helps
Adam
Old Jun 29, 2008 | 08:23 AM
collierm's Avatar
collierm
MP for K.I.S.S
If you've got XP SP2 at least, use WPA as its more secure than WEP. WEP can be broken by anyone with a free tool you can get off t'internet.
Use a pre- shared key when you set it up. This is a good guide to it
http://compnetworking.about.com/cs/w...nwindowsxp.htm
Matt
Old Jun 29, 2008 | 08:45 AM
cossie04's Avatar
cossie04
Hope that helps
Adam
How do i find my routers address? Sorry, i`m crap with computers.
I`m running XP if that helps...
Ed.
Old Jun 29, 2008 | 08:53 AM
Chris Honeywell's Avatar
Chris Honeywell
Ed.
Type either of those in the address bar,with my route though i have to be connected to it via a cable, then u basically are logged into the router
Old Jun 29, 2008 | 09:01 AM
cossie04's Avatar
cossie04
I`ve typed both in but it says "Page cannot be displayed"...
EDIT: I`ve done it. It was http://10.0.0.2. Cheers for the help peeps
PaulinhoT
Oct 28, 2015 06:06 PM
skypeller
Sep 19, 2015 09:58 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
cameron2
Aug 14, 2015 09:21 PM
