Ebay sweeeedish inlet...
Old Jun 28, 2008 | 02:49 PM
RWD Pete's Avatar
RWD Pete
Default Ebay sweeeedish inlet...
http://cgi.ebay.co.uk/COSWORTH-SWEDI...d=p3286.c0.m14
These any good? does anyone know if they are a tested product? i would ask the seller but im sure i would be delighted with the answer
Old Jun 28, 2008 | 03:12 PM
GlenS's Avatar
GlenS
Cheap and nasty crap, I speak from personal experience with those actual inlets. If I were you I would stick to the proper swedish ones or get one of those stainless versions.
Old Jun 28, 2008 | 04:00 PM
BRAMMER's Avatar
BRAMMER
Explain what is wrong with them??
Old Jun 28, 2008 | 04:08 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Cheap versions split like banana skins in high boost applications
Old Jun 28, 2008 | 04:11 PM
GlenS's Avatar
GlenS
Excatly what happened to mine. The guy who owned my car before me bought and fitted one of those exact inlets (to what is now my car) and it split not long ago. My mate TIG welded it up for me and it split again in another place. Absolutely awful quality and design imo.
Old Jun 28, 2008 | 04:14 PM
kjc300's Avatar
kjc300
I have had 3 split, teach me to buy cheap - should,ve got one off Mike Rainbird in the first place.
I'm testing a garage19 one now, see how that goes. Made of thicker ally than the others I've had.
Old Jun 28, 2008 | 10:47 PM
RWD Pete's Avatar
RWD Pete
They look quite sturdy to be fair its more the actual benefit of this inlet, if it works it is a fair price but is it worth risking.
Old Jun 28, 2008 | 10:52 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
just get a proper swedish one from r and b.
they are tested, they come with all you need to fit them, including a bling vaccum rail, they are quality.
Old Jun 28, 2008 | 10:55 PM
RWD Pete's Avatar
RWD Pete
That was my original plan mate, which i'll stick to.
Old Jun 29, 2008 | 08:06 AM
Garage19's Avatar
Garage19
How is it going with the current inlet that you are testing? It MAY or may not be of much stronger construction than normal swedish plenums and is welded to the trumpet section so there are no sealing problems. Kevin do you consider the one you are testing to be considerably better priced than even the one on ebay?
I have heard that in back to back testing on an engine dyno SOME swedish plenums have shown very good results even on a T34 engine.
(is that ok mods)
tankybaby66
Feb 6, 2016 02:24 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
2wdsaph ben
18
Oct 2, 2015 05:18 PM
Fil
Sep 30, 2015 12:08 PM
