focus rs offset
Old Jun 27, 2008 | 11:20 PM
NEWTON's Avatar
NEWTON
Default focus rs offset
what is the offset of focus rs wheels
Old Jun 27, 2008 | 11:21 PM
Rippers's Avatar
Rippers
Monte Geek
ET42
Old Jun 27, 2008 | 11:22 PM
NEWTON's Avatar
NEWTON
Originally Posted by Paul Ripley
ET42
would these fit a s2 rst
Old Jul 8, 2008 | 07:05 PM
NEWTON's Avatar
NEWTON
bump
Old Jul 8, 2008 | 09:42 PM
AlexRS2782's Avatar
AlexRS2782
iirc the offset for a series 2 is something like ET35 - with the FRS being ET42 & wheels 8" wide i doubt they will bolt straight on without the need for mods as the fronts would scrub on lock & the rears will likely rub as well so you would be looking at arch mods/rolling, etc, plus dependent on height of car, type of brakes be them standard or aftermarket calipers that may need to be factored in as well
From my time owning a Series 2 i'm sure i remember a few threads in the Escort turbo section on here with people fitting bigger 18's & having to modify the arches, brake pipes, etc
Old Jul 8, 2008 | 09:52 PM
fatboy billy's Avatar
fatboy billy
ive got frs wheels on my turbo cabrio they went straight on but as its lowered 35mm i had to roll the rear arches as it scrubbed on bumps and when the car had weight in it i also rolled the front arches too
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
