Noisey T5 Box On Idle
Just dropped a Cossie engine & box into a three door shell. Got it up and running but the gearbox appears to be noisey on idle, however it does disappear with the clutch down ??
The clutch appeared to have plenty of meat left on it, so I only replaced the clutch release bearing.
Any suggestions ????
Sounds like input shaft bearing to me also mate. Wouldnt say release bearing as that would be noisy when you press the clutch as thats when it engages. I had one T5 input shaft that wore the end away that goes into the spigot bearing...use to make a right racket, mangaged to swap it over for a decent one with out having to completly strip the box.
Sounds like input shaft bearing to me mate. Wouldnt say release bearing as that would be noisy when you press the clutch as thats when it engages. I had one T5 input shaft that wore the end away that goes into the spigot bearing...use to make a right racket, mangaged to swap it over for a decent one with out having to completly strip the box.
while you've got the box out you might as replace the spigot bearing too
http://cgi.ebay.co.uk/FORD-SIERRA-CO...QQcmdZViewItem
change the seals aswell; this seller normally lists the inputshaft bearing but doesnt appear to have any listed; should be no more than £22, i bought one the other day
Wow not as much as I dreaded
I fitted a new clutch cable today, so at least I've got one less thing to do !!!
Cheers Peeps
Steve Escos
Oct 1, 2015 06:57 AM
deathrider666
Sep 28, 2015 06:12 PM
Russ Payne
Sep 25, 2015 08:29 PM
