LRP fuel in an unleaded engine???
Old Jun 27, 2008 | 11:13 AM
vibrating_cake's Avatar
vibrating_cake
Default LRP fuel in an unleaded engine???
I have just bought a 2.0 zetec engine for the capri to transplant in with everything to go in!
but my problem is. i currently have a full tank of fuel with lead replacement juice in it (as the old pinto aint an unleaded engine)
would it be better to run this through the engine till the tanks nearenough empty and whack as much unleaded in as i can to dilute it as much as possible before the zetec goes in
or will it not do any harm to the newer engine, just make it run a little craply for a while as it runs through to pure unleaded??
Old Jun 27, 2008 | 11:21 AM
foreigneRS's Avatar
foreigneRS
Testing the future
no problem - would only kill the cat. if it had one
Old Jun 27, 2008 | 11:22 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
And lambda sensor - so remove this if it has one until tank is empty.
Old Jun 27, 2008 | 11:33 AM
vibrating_cake
thank god youtold me that one!!! them things are a cow to get off the manifold and replace!
although... i wont be runnin a cat... and will be running weber alpha management system with DCOE's... so it might not even have a lambada to worry about?
Old Jun 27, 2008 | 11:36 AM
foreigneRS's Avatar
foreigneRS
Testing the future
doh! forgot about the lambda sensor nice one mike
Old Jun 27, 2008 | 12:29 PM
RichieST's Avatar
RichieST
probably easier then to run the capri til its empty, drain out whatever is left and fill it with fresh unleaded
big_Rad
Sep 15, 2017 09:36 AM
ekjim
Aug 17, 2015 08:57 PM
Bailes1992
Aug 16, 2015 07:14 PM
muffster
Aug 12, 2015 08:14 PM
Old ford
Jul 31, 2015 06:50 AM
