my escort rs turbo s2 wont rev
Old Jun 27, 2008 | 07:50 AM
turbolee1977's Avatar
turbolee1977
Default my escort rs turbo s2 wont rev
hi please can someone help me???? my s2 is doin my head in. its popping banging stalling it wont idle. changed sparkplugs,dizzy,metering unit etc etc. . . . still the same!!!!!!
Old Jun 27, 2008 | 07:52 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Check for air leaks or your dip sticks not pushed back in properly !
Or oil filler cap,
jb
Old Jun 27, 2008 | 07:53 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
igniton timing? most probably the cause especially if u have changed/moved the dizzy
sounds like it needs retarting a little bit, do u have a timing gun?
could also be a vacumn leak, but timing wd be my first point of call
Old Jun 27, 2008 | 07:55 AM
turbolee1977
hi. thanks for replying it went to a garage for a week the bloke was stumped. just affords was stumped. a r.a.c bloke was stumped!!!! im on the verge of stripping it. i only rebuilt it from a bare shell 4 months ago and it was running fine
Old Jun 27, 2008 | 08:43 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
what did you build the car from and what was the base car
check your fuel pressure, what fuel tank have you used
Old Jun 27, 2008 | 08:50 AM
turbolee1977
everything basically brand new on car. car was running fine til it started doing that. brand new rs rurbo fuel tank when i rebuilt car
Old Jun 27, 2008 | 08:52 AM
Turbosystems
Super Moderator
was it a genuine ford tank
turbolee1977
the car running fine until i had prob with fuel pumps burning out parked car up for a week then sorted which i think was a dodgy earth wire. then it just started popping banging no revs etc etc since then
turbolee1977
yes it was a ford one
Old Jun 27, 2008 | 08:55 AM
Turbosystems
Super Moderator
check all your boost pipes are on properly ,particularly the turbo to intercooler and check for split pipes
Old Jun 27, 2008 | 08:57 AM
turbolee1977
thats my next job for 2day let u know thanks
Old Jun 27, 2008 | 11:22 AM
turbolee1977
checked all the pipes all are good!!!!!!!!!!!!!!
Old Jun 27, 2008 | 11:37 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Is the pump constantly runnin while turning the engine over & while the engine's coughin & banging ??
jb
Old Jun 27, 2008 | 11:52 AM
RANJ's Avatar
RANJ
check the mushroom breather, also check injectors are not leaking,check all air pipes, esp the one from metering unit to amal valve,
Old Jun 27, 2008 | 11:54 AM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
mine is doing the same i heard a gentle whistling whilst tryin to start it the other day, do u think thats an air leak?
Old Jun 27, 2008 | 12:08 PM
turbolee1977
jb
hi jb yes the pump is constantly on. forgot to say it wont rev either!!!!!
Old Jun 27, 2008 | 12:26 PM
Adam.'s Avatar
Adam.
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 16, 2015 12:57 PM
adriansaleem
Aug 1, 2015 09:28 PM
