Sold - Please Delete
Old Jun 26, 2008 | 08:46 PM
M K's Avatar
M K
Default Sold - Please Delete
ENGINE........
1.6cvh 8valve field motorsport built tall engine
1.6cvh block
all uprated bearings
fms spec low comp pistons
farndon steel rods (bshed for fully floating piston)
arp rod bolts
fms spec unground crank - knife edged/tuftrided/lightened & balanced/polished/baffled sump with cossie crank sensor bracket set up for cossie management
bottom crank pully converted for cossie management
arp stud and nut kit fitted
fully worked MFI head ported/polished/vernier/fms spec cam etc etc
fms spec cam sensor bracket and set up for cossie management
coilpack & custom bracket
fms spec plugs and leads to suit engine & heat proof lead boots
mutilayer steel headgasket
complete with the following ancillaries
rs 16i rocker cover in fms colour
oil cooler take off plate
tensioner
ford oil pump
ford water pump
timing belt
webber crank sensor
webber cam sensor
AP 4 paddle clutch with standard cver plate
flywheel
done approx 3000 miles
made 301bhp & 356lb/ft with a t34/greys/tubular manifods/p8/anti lag with graph to prove so easy a 300+bhp engine with the correc turbo/manifolds etc bolted to it.
no knocks/rattles/smoke or anything, doesnt use a single drop of oil ever, oil changed every 1000 miles or less
£2500.00 ono
block obviously had 3000 miles use since some of the photos but now on an engine stand so will give it a clean up while im there.
sump can be rmoved for inspection but not the head unless your gonna pay fms another £150 for another headgasket for it
Old Jun 28, 2008 | 04:56 PM
M K's Avatar
M K
Default my 300bhp fms cvh engine - OPEN TO OFFERS
pics from today -
Old Jun 29, 2008 | 08:45 PM
M K's Avatar
M K
Now Open To Offers
Old Jul 1, 2008 | 09:04 PM
M K's Avatar
M K
bttt
Old Jul 2, 2008 | 05:46 PM
M K's Avatar
M K
bttt - any offers at all
Old Jul 2, 2008 | 08:03 PM
Kop2381's Avatar
Kop2381
How much for the block and head alone as im only running MFi
Regards
Old Jul 2, 2008 | 08:21 PM
rapidcossie's Avatar
rapidcossie
proper engine!
Old Jul 3, 2008 | 04:27 PM
rst in breaking's Avatar
rst in breaking
good luck m.k, alot of money gone into this and always looks like it performs great
Old Jul 8, 2008 | 01:57 PM
M K's Avatar
M K
NOW 2K no offers.....Bargain!
Old Jul 8, 2008 | 02:14 PM
Bomber's Avatar
Bomber
I know you won't - but let me know if you decide to split the head and block - will take the head.
Old Jul 8, 2008 | 06:59 PM
M K's Avatar
M K
Regards
Whats your best offer?
M K's Avatar
M K
for what kind of price fella so i know? its an mfi head as well.
Old Jul 8, 2008 | 08:11 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
2k is a BARGAIN!!! Someones getting a good engine, without a doubt
Old Jul 8, 2008 | 08:53 PM
M K's Avatar
M K
you know that radders
Old Jul 9, 2008 | 03:15 PM
mart rs's Avatar
mart rs
id have the bottom end!
Old Jul 11, 2008 | 09:12 PM
rst in breaking
for sure someone will get a bargain, a fortune has been spent on this and done professionally too
Old Jul 12, 2008 | 09:22 PM
Paul.V's Avatar
Paul.V
Hi MK who done the work to the engine? Do you have receipts to back up the work? Was looking to do work to my S2 to go to a stage 3 but this thread has caught my eye, in for a penny..as they say!!
Old Jul 12, 2008 | 10:16 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Marc??!!
Old Jul 12, 2008 | 10:18 PM
Christian and Beccy
#1 in Spelling Club
Incidentally, that does look like an EFi head unless I am very much mistaken.
Old Jul 13, 2008 | 08:52 AM
M K's Avatar
M K
it has had the injector ports machined out for better spray pattern rather than just relying on the mfi to efi adapter plate to give enough clearance for a good spray, plus this way if you do want to use an efi inlet you just get the inlet part welded over and skimmed to seal to joining galleries.
Old Jul 13, 2008 | 08:54 AM
M K's Avatar
M K
hello mate, all work done by FIELD MOTORSPORT (01245 320 730) no receipts but you are welcome to get in contact with lynn or tommy to confirm they built the engine for me with all new parts etc less than 4000 miles ago, i do have the dyno sheets for the engine from fields dyno showing 356lb/ft & 301bhp running t34 @ 2bar. if you want more info then pm me
regards
marc
Old Jul 15, 2008 | 12:48 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Fucking hell, no proper bites at £2000? Some people are SO tight!!! This is a properly built engine for fuck sake and it has been proven, what more do people want?
Good luck with the sale Marc
Old Jul 15, 2008 | 02:05 PM
M K's Avatar
M K
i know tony, most people expect an engine like this for £500
Old Jul 15, 2008 | 04:14 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
how about £501the manifold going with it?
Old Jul 16, 2008 | 05:29 PM
M K's Avatar
M K
dream on fella..............
the manifold is for sale seperate for £500
Old Jul 16, 2008 | 07:03 PM
mart rs's Avatar
mart rs
you have pm
Old Jul 16, 2008 | 09:05 PM
samy66's Avatar
samy66
come on people dont be so tight get ya wallets out. the one hell of a engine. and a bargin if i ever saw one. wish i had that kind of money.
Old Jul 16, 2008 | 09:06 PM
M K's Avatar
M K
PROVISIONALLY SOLD TO MART RS
Old Jul 16, 2008 | 09:07 PM
SWITCHBLADE's Avatar
SWITCHBLADE
Passionate about fords
maybe theyre in the same situation as you, ie agree its a bargain and would love to have it but at the minute just short of the funds, anyway, BTTT.
dave
Old Jul 17, 2008 | 04:20 PM
mart rs's Avatar
mart rs
awsome!! :P
fordrallycar
Sep 30, 2015 07:57 PM
