Cossie Gear Ratios
Old Jun 26, 2008 | 06:24 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default Cossie Gear Ratios
What speed will a 2wd cossie do with a 7200rpm rev limit in each gear. Standard diff and box, with 205/40/17s and 215/40/17s.
Thanks
Steve.
Old Jun 26, 2008 | 07:56 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
1st = 47mph
2nd = 72mph
3rd = 104mph
4th = 139mph
5th = 174mph
Old Jun 26, 2008 | 08:46 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
1st = 47mph
2nd = 72mph
3rd = 104mph
4th = 139mph
5th = 174mph
What size tyre is that with Mike ????
Steve.
Old Jun 26, 2008 | 08:50 AM
Mike Rainbird
Caraholic
Surprisingly - what you asked for .
Old Jun 26, 2008 | 08:52 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
But i asked for 205/40/17s and 215/40/17s
So which one did you do ?????
Steve.
Old Jun 26, 2008 | 09:03 AM
Mike Rainbird
Caraholic
I thought you meant you had one size on the front and one on the rear . It is for the 215s. Obviously the 205s will be a few mph slower in each gear.
Old Jun 26, 2008 | 10:08 AM
GpA4x4's Avatar
GpA4x4
Don't suppose anyone has the 909 sport box ratios???
Old Jun 26, 2008 | 11:34 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
.........why mike........are the side walls a bit taller on the 215's...?????..............and while ur on nice chap.............whats the speeds on std 4x4 trans with 215/40/17's....................my limiter is 7500rpm
Old Jun 26, 2008 | 11:46 AM
marco polo's Avatar
marco polo
hi mate
will find out for you but not today tho sorry
marco
Old Jun 26, 2008 | 02:51 PM
Mike Rainbird
Caraholic
The profile is the aspect ratio of the tyre, so to find out the side wall height, you just multiply the width by the sidewall as a percentage, so obviously 40% of 205 is more than 40% of 215 .
Speeds would be:
1st = 40mph
2nd = 70mph
3rd = 107mph
4th = 146mph
5th = 178mph
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
The Youth.
Sep 30, 2015 09:59 PM
dojj
Sep 29, 2015 10:32 PM
